shptree not faster than no index
John Bolster
jb at NUCOMP.COM
Fri Sep 24 08:42:24 EDT 2004
Thanks for the advice. I'll try it this way on the counties. However, when I
start working with the other files, like roads, water and places, I'm
dealing with files that are currently broken down by county and each one may
have anywhere from 3,000 - 30,000 items per file. So that multiplied by
3,000 or so counties comes to 9 - 90 million items if I combined each record
type into one big file each. Would you still suggest combining them in these
cases, or do you think that gets too large?
John
> -----Original Message-----
> From: ANDY CANFIELD [mailto:andy_canfield at hotmail.com]
> Sent: Thursday, September 23, 2004 6:51 PM
> To: jb at NUCOMP.COM; MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] shptree not faster than no index
> I'd go with the one file of all counties. It's just easier to
> maintain one
> file than 3,000. I have at least 50 layers in one of my maps that
> each layer
> can have 300,000 to 1,000,000 plus objects in it. Using the shptree to
> create a .qix file makes these layers incredibly fast. I mean fast as in,
> you click on the map to zoom or pan, and as fast as your browser
> can render
> the map has been updated to reflect that pan or zoom. I think my smallest
> layer has 1,400 hundred polygons in it. Using the shptree and having one
> file is way easier than maintaining a single file for each boundary. I
> honestly don't think the map I'm using could be any faster, it is the
> browser/desktop rendering speed for me that limits how fast the image
> changes, so that's really, really fast. Plus if you have 3,000
> files and are
> zoomed to an extent where you can see half of them or more that's
> 1,500 or
> more open and read operations that Mapserver has to execute vice
> one if you
> put them all in the same file. My two cents anyway.
> >From: John Bolster <jb at NUCOMP.COM>
> >Reply-To: John Bolster <jb at NUCOMP.COM>
> >To: MAPSERVER-USERS at LISTS.UMN.EDU
> >Date: Thu, 23 Sep 2004 18:18:46 -0400
> >Thank you for your quick response.
> >In terms of the county outlines, do you think that one county
> per file, and
> >selecting which files to use with only a tileindex would be
> faster than all
> >counties being in one huge file of over 3000 counties and selecting which
> >counties to draw using a qix index?
> >Also, does the qix index on the actual tileindex do anything to speed up
> >the
> >tileindex?
> >Thanks,
> >John
> > > From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> > > Sent: Thursday, September 23, 2004 6:13 PM
> > > To: John Bolster
> > > Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> > > John Bolster wrote:
> > > > Hi all,
> > > > I'm noticing there doesn't seem to be any difference in speed
> > > between having
> > > > *.qix files vs. not having them. I'm wondering if I'm doing this
> >right.
> > > > My data is from tiger and is in shapefiles. I'm only dealing with
> >county
> > > > outlines right now. They are each in a separate folder, each state's
> > > > counties are in one state folder. There's a tileindex on
> them all at
> >the
> > > > root of the tree.
> > > John,
> > > The impression I get is that you have exactly one county polygon
> > > per shapefile.
> > > Is that right? A .qix won't help because it is used to more
> > > quickly select
> > > the subset of shapes in a shapefile based on the extents. If you
> > > only have
> > > one shape per file then it can't help.
> > > Of course, the tileindex should allow you to quickly select the county
> > > files you want. But a more efficient approach would likely
> be to have
> >one
> > > shapefile with a .qix with all your county outlines in it.
> > > Best regards,
> > > I set the clouds in motion - turn up | Frank Warmerdam,
> > > light and sound - activate the windows | http://pobox.com/~warmerdam
> > > and watch the world go round - Rush | Geospatial
> Programmer for Rent
> _________________________________________________________________
> FREE pop-up blocking with the new MSN Toolbar get it now!
> http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
