[UMN_MAPSERVER-USERS] Help with MAP File
Skweda O'Bomsawin
sobomsawin at KASSINI.COM
Fri Sep 24 10:35:32 EDT 2004
Exactly. You need a projection block in your map section and another
projection block in your layer section. The PROJECTION block of the map
section is for reprojection on-the-fly feature of Mapserver. This means you
can choose in which projection you want to display your date in this
section. The PROJECTION block of the layer is the current projection of
your data (you must know the current projection of your data and specify it
there).
If you specify that your units are in meters, that means you must specify a
projection (not latlong). The most usual projection for units in meters is
UTM. Here is a sample PROJECTION block for UTM:
PROJECTION
"proj=utm"
"ellps=GRS80"
"zone=15"
"north"
"no_defs"
END
Parameters of the PROJECTION block are simply proj4 parameters. I recommend
you take a look at http://mapserver.gis.umn.edu/coordinates.html and
http://www.remotesensing.org/proj/
Hope this will help!
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Pablo Toapanta
Envoyé : 24 septembre 2004 09:29
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Help with MAP File
Hi
This is my map file:
MAP
IMAGETYPE PNG
EXTENT 495591.176607842 9972721.25772341
505382.102073711 9984983.97959341
SIZE 1000 800
SHAPEPATH "data"
IMAGECOLOR 255 255 255
UNITS meters
PROJECTION
# "proj=latlong"
# "ellps=clrk66"
# "lat_0=0"
# "lon_0=0"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
# Start of LAYER DEFINITIONS --------------------
LAYER # States polygon layer begins here
NAME states
DATA quiton45
STATUS ON
TYPE POLYGON
PROJECTION
#"proj=latlong"
#"init=epsg:4326"
END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------
END # end of map file/object
I think that the problem is with the extent or the
projection. Please help me with this, it´s very
important. I don´t know how to obtain the correct
extent.
Thanks
Pablo Toapanta N.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.767 / Virus Database: 514 - Release Date: 2004-09-21
Outgoing mail is certified Virus Free.
