PhpMapscript says ms_png not defined
John Kim
jkim at SCIENCES.SDSU.EDU
Fri Sep 24 20:12:21 EDT 2004
I just installed PHPMapScript and tried running a simple PHP script with a
test map, and the resulting html says, "use of undefined constant MS_PNG".
Where should this have been defined? (I had a similar problem when I tried
the GMap demo, except it said MS_GIF was undefined.)
Here's my PHP code:
dl("php_mapscript_42.dll");
$map = ms_newMapObj("test.map");
print $map->numlayers; // this line prints 4
$img = $map->draw();
$url = $img->saveWebImage(MS_PNG, 0, 0, 0);
I'm using Mapserver 4.2.3, PHP 4.3.9, PHP Mapscript 4.2, and Apache 2.0
on Windows 2000. Did I not configure something right?
Thanks,
John Kim
