USGS Urban133 Ortho Imagery via WMS
Thomas Chesky thomaschesky at YAHOO.COM
Sun Sep 26 15:32:21 EDT 2004
Tyler,
I have 3 png files with different output projection (500Kb each, I am not sure if it's OK to post such big files on the list, confirm, and I will send them)
All are slightly reprojected (that is: something happening with the image when requesting other projection) but only 4326 produces correct overlays (the default and only USGS WMS projection).
layers: USGS ortho, parcel, FEMA hazards
I am testing via the cgi interface with the following parameters:
1.,
/cgi-bin/mapserv?mode=map&map=/usr/local/mapapp/map.map&layers=SanFrancisco01%20Q3Flood%20san_mateo_cou_ca_apn&mapext=-122.226813776775+37.4764381661621+-122.213167520107+37.4835588561656&mapsize=600+400&map_projection=init%3Depsg:2227
2.,
/cgi-bin/mapserv?mode=map&map=/usr/local/mapapp/map.map&layers=SanFrancisco01%20Q3Flood%20san_mateo_cou_ca_apn&mapext=-122.226813776775+37.4764381661621+-122.213167520107+37.4835588561656&mapsize=600+400&map_projection=init%3Depsg:4326
3.,
/cgi-bin/mapserv?mode=map&map=/usr/local/mapapp/map.map&layers=SanFrancisco01%20Q3Flood%20san_mateo_cou_ca_apn&mapext=-122.226813776775+37.4764381661621+-122.213167520107+37.4835588561656&mapsize=600+400&map_projection=init%3Depsg:26910
I removed units and projection from the map file as you suggested
# UNITS DD
# PROJECTION
# "init=epsg:26910"
# END
Same problem. Is it possible that reprojection using epsg on raster layer causes the problem? I doubt, but everything else looks fine otherwise and the parcels are reprojected correctly, but the raster WMS layer is not.
Any idea?
Thanks
Tyler Mitchell <tylermitchell at shaw.ca> wrote:
> Is there any special thing to know re: reprojecting raster layers?
Shouldn't be!
> UNITS DD
> PROJECTION
> "init=epsg:26910"
> END
Really? Decimal Degrees (DD) for UTM Zone 10 projection that is in metres?
Tyler
Do you Yahoo!?
vote.yahoo.com - Register online to vote today!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040926/08042f75/attachment.html
