[UMN_MAPSERVER-USERS] Query not showing Map/Scale/Legend
Skweda O'Bomsawin sobomsawin at KASSINI.COM
Mon Sep 27 09:24:51 EDT 2004
Ike,
To get the Mapserver demo working, you must at least:
1-       Have a working installation of Apache with CGI support
2-       Have a working installation of Mapserver CGI
3-       Change variables of the Map file (SHAPEPATH, TEMPLATE and WEB block
particularly) according to your system
4-       Change variables of the HTML files according to your system
You can verify your Mapserver CGI installation by sending a test URL to your
server (see the doc from Mapserver web site).  I recommend you take a look
at this tutorial which will guide you through the installation and testing
process:
HYPERLINK
"http://terrasip.gis.umn.edu/projects/tutorial/"http://terrasip.gis.umn.edu/
projects/tutorial/
Otherwise, you can use the DMSolutions Maplab product:
HYPERLINK
"http://www.dmsolutions.ca/techserv/maplab.html"http://www.dmsolutions.ca/te
chserv/maplab.html
Best regards,
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Ike Brian
Envoyé : 25 septembre 2004 21:19
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Query not showing Map/Scale/Legend
Thank you very much for the reply.I have downloaded the demo as u said and
have followd all the necessary steps.
When I clicked on intialise the page the opened did not show the following
*         the map
*         legend
*         scale
But all other things showed up.I would like to know if there is something
else that I should do to show up the above mentioned objects.
I think that image type is the problem.Hoping to hear from you.
Isaac
done as you said.
David Fawcett <David.Fawcett at state.mn.us> wrote:
Ike,
I recommend that you downloat the demo and get that up and running.
