asp and mapserver
C Gould
craig.gould at BT.COM
Mon Sep 27 10:02:37 EDT 2004
Steve,
Can you not create a page that :
1. Does your preprocessing with the database and creates your mapserver
cgi url.
2. Uses a third party product (e.g. w3sockets
http://www.dimac.net/Products/FreeProducts/w3Sockets/start.htm ) to call
the mapserver cgi-script and retrieve the resulting HTML which will
contain the newly created GIF's URL.
3. Pass this GIF URL onto the other HTML page.
Regards
Craig
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Steve McCrone
Sent: 27 September 2004 14:45
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] asp and mapserver
Is there a way to mix asp and mapserver?
I need to access a database using asp, and then use some of the reults
to create a GIF using mapserver, and then pass the gif file name created
to another html page.
The problem is that I cannot seem to mix mapserver and asp.
Thanks
