Problems with Positioning Names from MapInfo TAB file
Bob Bruce
covariance at SHAW.CA
Tue Sep 28 09:49:32 EDT 2004
Hi:
I am trying to use a TAB file that has names positioned on blockfaces.
In the MapInfo ProViewer (a free viewer from MapInfo) I can view the file
and see the street annotation positioned at the various angles that they run
along the streets. But when I try and display this in MapServer I only get
them positioned horizontally. I tried using the LABEL object but it wouldn't
display them at all so I reverted to the STYLEITEM "AUTO" command and it put
the labels out but only horizontally.
Does anyone know how to get MapServer to use the angles stored with the
text in the file? My map file is included below. The blckface file has both
lines for blockfaces and text elements in it. Here is some same output from
the OGRINFO program:
OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4532
ID (Integer) = 6152
Style = PEN(w:1px,c:#d9bb15,id:"mapinfo-pen-2.ogr-pen-0")
LINESTRING (634272.418 5523967.692,634279.402 5523966.363)
OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4533
ID (Integer) = 6209
Style = LABEL(t:"KINGSTON",a:358.700000,s:15.996744g,c:#000000,p:1,f:"Arial")
POINT (634312.023 5524049.501)
OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4534
ID (Integer) = 6498
LINESTRING (634214.639 5524099.705,634218.473 5524099.606,634229.861
5524098.786)
OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4535
ID (Integer) = 6640
LINESTRING (634211.638 5523974.631,634214.078 5523973.711,634223.050
5523971.702,634226.793 552397
1.362)
OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4536
ID (Integer) = 1893
Style = LABEL(t:"VICTORIA
GR",a:333.600000,s:15.996744g,c:#000000,p:1,f:"Arial")
POINT (634252.281 5522621.452)
here you can see both text and lines.
thanks,
Bob Bruce
NAME St_Boniface_Vital_s2ex1
# EXTENT 632862.444326 5510719.468992 642031.781954 5529899.634924
# EXTENT 633000 5521000 641000 5528000
EXTENT 633850 5525850 635050 5527050
SIZE 400 400
LAYER # Polling Subdivision
NAME "Polling Subdivision"
CONNECTIONTYPE OGR
CONNECTION
"C:/Apache/htdocs/MapserverTutorial/StBonifaceStVital/St_Boniface_Vital_Data/PollingSubDivision.tab"
STATUS DEFAULT
TYPE POLYGON
CLASS # Polling Subdivision <= 250
NAME "Polling Subdivision <= 250"
EXPRESSION ([Population] <= 250)
COLOR 255 204 204
OUTLINECOLOR 0 0 0
END # end of Whole DLS Parcel class object
CLASS # Polling Subdivision <= 500
NAME "Polling Subdivision <= 500"
EXPRESSION ([Population] <= 500)
COLOR 250 128 128
OUTLINECOLOR 0 0 0
END # end of Part DLS Parcel class object
CLASS # Polling Subdivision <= 750
NAME "Polling Subdivision <= 750"
EXPRESSION ([Population] <= 750)
COLOR 255 40 40
OUTLINECOLOR 0 0 0
CLASS # Polling Subdivision <= 1000
NAME "Polling Subdivision <= 1000"
EXPRESSION ([Population] <= 1000)
COLOR 200 0 0
OUTLINECOLOR 0 0 0
END # end of layer object
LAYER # Street Lines
NAME "Street Lines"
CONNECTIONTYPE OGR
CONNECTION
"C:/Apache/htdocs/MapserverTutorial/StBonifaceStVital/St_Boniface_Vital_Data/st_Vital_Boniface_blkface.tab"
STATUS DEFAULT
TYPE LINE
# STYLEITEM "AUTO"
CLASS
STYLE
# COLOR 255 146 36
COLOR 255 255 0
END
END
END
LAYER # Street Names
NAME "Street Names"
CONNECTIONTYPE OGR
CONNECTION
STATUS DEFAULT
TYPE ANNOTATION
STYLEITEM "AUTO"
CLASS
# LABEL
# ANGLE AUTO
# COLOR 0 0 0
# COLOR 43 255 177
# SIZE SMALL
# TYPE BITMAP
# END
END
END
END # end of map file
