Projections and WMS servers
Nico Alberti
nico.alberti at GMAIL.COM
Tue Sep 28 11:30:57 EDT 2004
On Tue, 28 Sep 2004 11:01:46 -0400, Ed McNierney <ed at topozone.com> wrote:
> Nico -
> Can you send the URL of the WMS server you're using? The only service I can find on that site is a WFS feature service.
I used this one. Somehow it displays something, so I hope it is the
right service :-)
http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?
> You need to be able describe the projection of the data coming from the WMS service, and MapServer will request the data in that projection (which must, of course, be a supported projection on that server).
And I guess I can know that querying for its capabilities and looking
for epsg:26951 in the xml file I receive, can't I? I did not see it,
and if I do:
LAYER
NAME "Esrin"
STATUS ON
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?"
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 0
TOLERANCEUNITS PIXELS
METADATA
"wms_srs" "epsg:26951"
"wms_name" "WATRCRSL_1M:Foundation:CubeWerx"
"wms_server_version" "1.1.1"
"wms_formatlist" "image/gif,image/png,image/jpeg,image/wbmp"
"wms_format" "image/gif"
END
PROJECTION
"init=epsg:26951"
END
END
I get a blank layer (while other ones are correctly displayed)
> You will have two types of PROJECTION blocks in your map file. You should have one for each LAYER, describing the native projection in which that layer's data is stored. And you should have one at the top level of your map file, indicating what *output* projection should be used in producing the requested map.
> The PROJECTION block below is superficially OK, but it's certainly not the Monte Mario
Uh. Yes, you are right. For some reason, I thought using epsg:26951
would not have worked.
Thank you for your help!
Ciao
Nico
