[UMN_MAPSERVER-USERS] Help In Accessing/Displaying Mapscripts
Skweda O'Bomsawin sobomsawin at KASSINI.COM
Wed Sep 29 10:43:57 EDT 2004
Ike,
You can run your phtml like any other html file from your web server.  To do
that, you just have to set the type in your httpd.conf file (if you are
using Apache of course):
AddType application/x-httpd-php .php .phtml
AddType application/x-httpd-php-cgi .php .phtml               # If you want
to run php as cgi
Action application/x-httpd-php-cgi /cgi-bin/php433             # Where is
your php cgi application
Of course, you must have compiled Apache and PHP to work together (see
HYPERLINK
"http://mapserver.gis.umn.edu/doc42/phpmapscript-install-howto.html"http://m
apserver.gis.umn.edu/doc42/phpmapscript-install-howto.html or search Google
for an installation adapted to your OS).
This way, you will be able to call your application as HYPERLINK
"http://your.host/your_script.phtml"http://your.host/your_script.phtml
P.S. These USA demo files have to be edited to your settings before you can
run them
  See the Mapserver installation and PHP/Mapscript documentation.
Cheers!
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Ike Brian
Envoyé : 29 septembre 2004 00:02
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Help In Accessing/Displaying Mapscripts
Hello,
I have PHP/Mapscript *.phtml files but dont know how to access them.These
data are from the mapserver web they are already programmed files but want
to know how to access *.phtml files.These are the USA files from HYPERLINK
"http://www.mobilegeographics.com/mapserver/"http://www.mobilegeographics.co
m/mapserver/
Could anyone in how I can display the map using these files.I am only used
to html files.
Skweda O'Bomsawin <sobomsawin at KASSINI.COM> wrote:
Ike,
To get the Mapserver demo working, you must at least:
1-       Have a working installation of Apache with CGI support
2-       Have a working installation of Mapserver CGI
3-       Change variables of the Map file (SHAPEPATH, TEMPLATE and WEB block
particularly) according to your system
4-       Change variables of the HTML files according to your system
You can verify your Mapserver CGI installation by sending a test URL to your
server (see the doc from Mapserver web site).  I recommend you take a look
at this tutorial which will guide you through the installation and testing
process:
HYPERLINK
"http://terrasip.gis.umn.edu/projects/tutorial/"http://terrasip.gis.umn.edu/
projects/tutorial/
Otherwise, you can use the DMSolutions Maplab product:
HYPERLINK
"http://www.dmsolutions.ca/techserv/maplab.html"http://www.dmsolutions.ca/te
chserv/maplab.html
Best regards,
Skweda O'Bomsawin
part de Ike Brian
Envoyé : 25 septembre 2004 21:19
Objet : [UMN_MAPSERVER-USERS] Query not showing Map/Scale/Legend
Thank you very much for the reply.I have downloaded the demo as u said and
have followd all the necessary steps.
When I clicked on intialise the page the opened did not show the following
*         the map
*         legend
*         scale
But all other things showed up.I would like to know if there is something
else that I should do to show up the above mentioned objects.
I think that image type is the problem.Hoping to hear from you.
Isaac
done as you said.
David Fawcett <David.Fawcett at state.mn.us> wrote:
Ike,
I recommend that you downloat the demo and get that up and running.
