AW: [UMN_MAPSERVER-USERS] Newbie question - building GDAL
Engel Gerhard
Gerhard.Engel at SBG.AC.AT
Wed Sep 29 11:25:51 EDT 2004
Thanks Frank & the others,
The GDAL question has been solved.
It's the last point you mention I don't manage to handle:
The path to/of my grid (binary) directory is
c:\projects\abtenau\geodata\abtdem\
The SHAPEPATH is set to "c:\projects\abtenau\geodata" and for the
DATA-parameter of my grid file I assume "abtdem/hdr.adf" is correct or am I
mistaken here?!
I have tried all sorts of path variation now but none will work. Or do I
have to leave out the PROJECTION object for the grid layer?
Kind regards,
Gerhard
Gerhard Engel
Gerhard.Engel at sbg.ac.at
Z_GIS Zentrum für Geoinformatik * Universität Salzburg * Hellbrunnerstraße
34 * A-5020 Salzburg
tel. +43 662 8044-5223 * fax +43 662 8044-525
web: http://www.zgis.at
> -----Ursprüngliche Nachricht-----
> Von: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Gesendet: Wednesday, September 29, 2004 3:37 PM
> An: Gerhard Engel
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] Newbie question - building GDAL
> Gerhard Engel wrote:
> > Hallo,
> > I am relatively new to the MapServer world and would like
> to display
> > an ArcInfo grid. My MS-version is 4.2.3 with input support
> for GDAL. I
> > have read most(?) of the documentation about displaying
> raster files
> > but using the GDAL library in practive is still unclear to me. Do I
> > need to compile the downloaded 1.2.1 library? If this is the case
> > please be patient with my ignorance, but: how do I compile this
> > stuff?? - I've never had this to do before so any
> instructions would be welcome.
> Gerhard,
> If you have a MapServer with GDAL support already you should
> not need to do anything special to use Arc/Info Binary Grids
> (I assume that is what you mean by arcinfo grid - there are
> also ascii equivelents). The only trick with grids is how
> you name the grid. The easiest way to refer to the grid is
> by giving the name of the hdf.adf file the grid directory.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
