SWIG Mapscript
Ryan, Adam ARyan at CO.LINN.OR.US
Wed Sep 29 17:07:14 EDT 2004
> -----Original Message-----
> From: Ryan, Adam [mailto:ARyan at CO.LINN.OR.US]
> Sent: Wednesday, September 29, 2004 1:50 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] SWIG Mapscript
> > From: Lowell Filak [mailto:lfilak at medinaco.org]
> > Sent: Wednesday, September 29, 2004 1:38 PM
> > To: Ryan, Adam; Lowell Filak
> > Subject: RE: [UMN_MAPSERVER-USERS] SWIG Mapscript
> > The following message was sent by "Ryan, Adam"
> <ARyan at co.linn.or.us>
> > on Wed, 29 Sep 2004 13:25:52 -0700.
> > > > Sent: Wednesday, September 29, 2004 12:42 PM
> > > > To: Ryan, Adam; MAPSERVER-USERS at LISTS.UMN.EDU
> > > > <ARyan at CO.LINN.OR.US> on Wed, 29 Sep 2004 11:54:34 -0700.
> > > > > Mapservers,
> > > > > Two methods I use in php mapscript don't seem to be
> in the SWIG
> > > > > version.
> > > > > Layer->queryByIndex - this is non-critical since I can use
> > > > queryByAttribute
> > > > > with an FID
> > > > > Map->loadQuery - this is critical.  There is a saveQuery
> > > > method, but
> > > > > Map->no
> > > > > loadQuery?
> > > > > Thanks for any insight.
> > > > > Adam
> > > > Adam,
> > > > If I understand saveQuery correctly, you can do
> something similar
> > > > to this by using the shapeindex for each result to pull
> the shapes
> > > > out of the original layer (if it's a
> > > > shapefile) and writing each shape to a new shapefile.
> This doesn't
> > > > combine all result layers into a single file however,
> it means one
> > > > shapefile for each layer with a result(s). No wonder
> there isn't a
> > > > loadQuery, parsing all the particulars back out of a
> single file
> > > > would be interesting if you change layer ordering at any point.
> > > > Lowell
> > > Hey, thanks for the reply.
> > > I think saveQuery and loadQuery are terrific methods.  Building
> > > shapefiles does not allow for dynamic queries using AND,
> OR, or XOR
> > > with previous queries, and it's too slow.  The layer index
> > problem is
> > > easily handled by changing the layer index value in the
> saved query
> > > file itself prior to loading.  As long as only one layer is
> > queried at
> > > a time, this works well.
> > > I'm trying to re-write an application using Python and
> without this
> > > functionality it's a no go.  I can't even emulate a
> > saveQuery because
> > there
> > > is no queryByIndex method.  I'm at a loss.
> > > Adam
> > Adam,
> > So it sounds like your already down to a single layer being
> saved. I
> > guess I am missing what you mean by "AND, OR, or XOR" queries as we
> > use queryByFeatures to perform a second query based on the
> results of
> > a previous query.
> > Lowell
> As far as I understand, queryByFeatures works in the same
> session.  Using query files, I'm able to allow the user to
> AND, OR, and XOR a previous query in another session by
> loading the previously saved .qy query file.  It's a
> round-about way of reading the previous file into an array,
> running the new query, getting that as an array, relating the
> arrays, and saving the array to yet another qy file.  It's
> not pretty, but it works.  And with saveQuery & loadQuery,
> it's pretty fast.
> Adam
By the way, saveQuery does work correctly in SWIG mapscript.  I read the
file when populating a result table and the results are correct so far.
Adam
