hidden variable settings
David Fawcett
David.Fawcett at STATE.MN.US
Wed Sep 29 18:32:20 EDT 2004
Manjiri,
This may not be the only problem that still exists, but I did see one
error.
Because you are on Windows, you need to add '.exe' to the program name.
Like this:
<input
type="hidden" name="program" value="c:/Inetpub/wwwroot/MapServer/cgi-
bin/mapserv.exe">
David J. Fawcett
MN Office of Environmental Assistance
>>> Manjiri Andhare <manjiri_r at HOTMAIL.COM> 09/29/04 1:16 PM >>>
David,
Thanks for providing me with the information about creating a directory
for
writing temporary files. I have created the directory
C:/Inetpub/wwwroot/MapServer/Docs/tmp.
I have given IIS rights to read and write to these directories.
And i edited the hidden variables as:
<!-- EDIT THESE HIDDEN VARIABLES -->
<input type="hidden"
name="map"value="c:/Inetpub/wwwroot/MapServer/itasca.map">
<input
type="hidden"name="program"value="c:/Inetpub/wwwroot/MapServer/cgi-
bin/mapserv">
<input type="hidden" name="root"
value="c:/Inetpub/wwwroot/MapServer">
<input type="hidden" name="map_web_imagepath"
value="c:/Inetpub/wwwroot/MapServer/Docs/tmp/">
<input type="hidden" name="map_web_imageurl" value="/Docs/tmp/">
But still when I hit the "Initialize" button, I get "The Page can not be
displayed" error.
Do you have any idea about whats goin wrong here?
Thank you again,
Manjiri
On Wed, 29 Sep 2004 11:41:04 -0500, David Fawcett
<David.Fawcett at STATE.MN.US> wrote:
>Manjiri,
>the tmp directory is a directory that you have to set up on your server
>and your Web server needs to have read and write access to the
>directory. It doesn't have to be called 'tmp'. It should be in your
>Web root because it also needs to be referenced as a URL.
>The variable 'map_web_imagepath' is used to set the IMAGEPATH value in
>the WEB block of your MAP file. There is more documentation on that
>here: http://mapserver.gis.umn.edu/doc42/mapfile-reference.html#web .
>It should contain the path to the 'tmp' directory that you want
>MapServer to write the map images to. (e.g. '/usr/local/www/docs/tmp/'
>on 'NIX or 'c:\apache\htdocs\tmp\' on Windows.)
>Similarly, 'map_web_imageurl' refers to IMAGEURL in the Web block. (see
>above documentation URL) It refers to the URL to the same 'tmp'
>directory above, but as a URL, not a path. (e.g.
>'http://my.site.com/tmp/') For most sites, like the demo you are
using,
>it is expressed as a relative URL (e.g. '/tmp/')
>Good Luck,
>David.
>David J. Fawcett
>>>> Manjiri Andhare <manjiri_r at HOTMAIL.COM> 9/29/2004 10:59:39 AM >>>
>Hello!!
>I'm trying to run the demo application which is on the
>http://mapserver.gis.umn.edu/dload.html . I have extracted the
>workshop.exe, and have created a folder under cgi-bin directory. In
>the
>readme file of workshop demo, they have stated to change the hidden
>variable settings in index.htm file, i'm not getting where to set the
>hidden variables for following 2 things:
>value="/usr/local/www/docs/tmp/">
> <input type="hidden" name="map_web_imageurl" value="/tmp/">
>I don't see any tmp directory in the workshop(, though there is a
>templets
>directory), is this the same?
>Manjiri
