SWIG Mapscript
Umberto Nicoletti
unicoletti at PROMETEO.IT
Thu Sep 30 03:08:17 EDT 2004
Hi Adam,
some time time ago I also wanted to use save/loadQuery from Java
mapscript.
My workaround is to save query parameters in the user's session and run
the query every time until it is cleared on explicit user request or
another query is run.
This keeps the result consistent even if the user changes layers display
properties (hides/shows a layer).
I did not notice any significant slowdown.
HTH,
Umberto
On Wed, 2004-09-29 at 22:37, Ryan, Adam wrote:
> > -----Original Message-----
> > From: Sean Gillies [mailto:sgillies at FRII.COM]
> > Sent: Wednesday, September 29, 2004 12:19 PM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: Re: [UMN_MAPSERVER-USERS] SWIG Mapscript
> > On Sep 29, 2004, at 1:16 PM, Sean Gillies wrote:
> > > On Sep 29, 2004, at 12:54 PM, Ryan, Adam wrote:
> > >> Mapservers,
> > >> Two methods I use in php mapscript don't seem to be in the SWIG
> > >> version.
> > >> Layer->queryByIndex - this is non-critical since I can use
> > >> queryByAttribute
> > >> with an FID
> > >> Map->loadQuery - this is critical. There is a saveQuery
> > method, but
> > >> no
> > >> loadQuery?
> > >> Thanks for any insight.
> > >> Adam
> > > Adam,
> > > Since I've used the PHP mapscript, I'm not sure what loadQuery and
> > > saveQuery are for. Explain?
> > > Sean
> > Sorry, meant to say that I've *never* used the PHP mapscript
> > and don't understand the use for saving and loading queries.
> > Sean
> Hey, thanks for the reply.
> Am I the only one using saveQuery? I think saveQuery and loadQuery are
> terrific methods. They generate/read small files of shape index values -
> similar, to a bitmap in Avenue I think. By loading a saved query, I can
> return a layer to a previous query 'state', for lack of a better word
> (resultCacheObj state?). This is extremely useful.
> Building shapefiles does not allow for dynamic queries using AND, OR, or XOR
> with previous queries, and it's too slow. The layer index problem is easily
> handled by changing the layer index value in the saved query file itself
> prior to loading. As long as only one layer is queried at a time, this
> works well.
> I'm trying to re-write an application using Python and without this
> functionality it's a no go. I can't even emulate a saveQuery because there
> is no queryByIndex method, and even if there was, stepping through a list of
> indexes and calling queryByIndex is MUCH slower than the loadQuery method.
> I'm at a loss.
> Adam
