ApplySLD creates incorrect filter
Berend Veldkamp
berend.veldkamp at ARIS.NL
Thu Sep 30 07:50:38 EDT 2004
Hello all,
I have the following filter in an sld:
<And>
<PropertyIsBetween>
<PropertyName>X</PropertyName>
<LowerBoundary>143692</LowerBoundary>
<UpperBoundary>145692</UpperBoundary>
</PropertyIsBetween>
<PropertyIsBetween>
<PropertyName>Y</PropertyName>
<LowerBoundary>461308</LowerBoundary>
<UpperBoundary>463308</UpperBoundary>
</And>
When I do a direct getmap request to a Mapserver WMS server (for example
http://localhost/mapserv&map=test.map&service=wms&version=1.1.0&request=getmap&layers=nap&styles=&sld=test.sld),
it works. However when I use PHP/MapScript it doesn't.
When I call ApplySLD, MapServer creates a class with the following
expression:
EXPRESSION ( ([X] >= 143692 AND [X] <= 145692) And ([Y] >= 461308
AND [Y] <= 463308))
Since this is a WMS layer, MapServer tries to translate this expression
back to a valid filter when making the getmap request, but fails. I
experimented a bit , and I found that It only works with a maximum of 2
conditions, and only using ">" or "<", not "<=" or ">=", i.e. ( ([X] >
143692 AND [X] < 145692) )
This is the filter that MapServer creates in this case:
<AND>
<ogc:PropertyIsGreaterThan>
<ogc:PropertyName>X</ogc:PropertyName>
<ogc:Literal>143692</ogc:Literal>
</ogc:PropertyIsGreaterThan> <ogc:PropertyIsLessThan>
<ogc:Literal>145692</ogc:Literal>
</ogc:PropertyIsLessThan>
</AND>
Now I don't really care if it's "greater than" or greater than or equal
to", but I really would like to be able to use more than 2 conditions.
I'm not sure if this is possible at all, can anyone comment on this?
Thanks, Berend
____________________________
Berend Veldkamp - ARIS
http://www.aris.nl/
