SWIG Mapscript
Ryan, Adam
ARyan at CO.LINN.OR.US
Thu Sep 30 13:13:20 EDT 2004
> -----Original Message-----
> From: Sean Gillies [mailto:sgillies at frii.com]
> Sent: Thursday, September 30, 2004 9:41 AM
> To: Ryan, Adam
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] SWIG Mapscript
> >> Sent: Thursday, September 30, 2004 7:45 AM
> >> To: Ryan, Adam
> >>>> From: Sean Gillies [mailto:sgillies at FRII.COM]
> >>>> Sent: Wednesday, September 29, 2004 12:19 PM
> >>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
> >>>>> On Sep 29, 2004, at 12:54 PM, Ryan, Adam wrote:
> >>>>>> Mapservers,
> >>>>>> Two methods I use in php mapscript don't seem to be in
> the SWIG
> >>>>>> version.
> >>>>>> Layer->queryByIndex - this is non-critical since I can use
> >>>>>> queryByAttribute
> >>>>>> with an FID
> >>>>>> Map->loadQuery - this is critical. There is a saveQuery
> >>>> method, but
> >>>>>> no
> >>>>>> loadQuery?
> >>>>>> Thanks for any insight.
> >>>>>> Adam
> >>>> Sorry, meant to say that I've *never* used the PHP mapscript and
> >>>> don't understand the use for saving and loading queries.
> >>>> Sean
> >>> Hey, thanks for the reply.
> >>> Am I the only one using saveQuery? I think saveQuery and
> loadQuery
> >>> are terrific methods. They generate/read small files of
> >> shape index
> >>> values - similar, to a bitmap in Avenue I think. By
> >> loading a saved
> >>> query, I can
> >>> return a layer to a previous query 'state', for lack of a
> >> better word
> >>> (resultCacheObj state?). This is extremely useful.
> >>> Building shapefiles does not allow for dynamic queries
> >> using AND, OR,
> >>> or XOR
> >>> with previous queries, and it's too slow. The layer index
> >> problem is
> >>> easily
> >>> handled by changing the layer index value in the saved query file
> >>> itself prior to loading. As long as only one layer is queried at
> >> a time, this
> >>> works well.
> >>> I'm trying to re-write an application using Python and
> without this
> >>> functionality it's a no go. I can't even emulate a
> >> saveQuery because
> >>> there is no queryByIndex method, and even if there was, stepping
> >>> through a list of indexes and calling queryByIndex is MUCH slower
> >>> than the loadQuery method.
> >>> I'm at a loss.
> >>> Adam
> >> Adam,
> >> Thanks for the explanation. I am not against implementing the PHP
> >> savequery and loadquery, although I do question why these methods
> >> write and read
> >> from
> >> the filesystem when your logical combination needs to be done
> >> in memory.
> >> Meanwhile, for 4.2, I have an idea. Instead of manipulating the
> >> layer's resultcache in place, create Python sets of query
> results and
> >> do your logical
> >> operations on them. For example::
> >> import sets
> >> layer.query1() # assume success
> >> qset1 = sets.Set()
> >> for i in range(layer.getNumResults()):
> >> result = layer.getResult(i)
> >> result_tuple = (result.shapeindex, result.tileindex,
> >> result.classindex)
> >> qset1.add(result_tuple)
> >> layer.query2() # assume success
> >> qset2 = sets.Set()
> >> result.classindex)
> >> qset2.add(result_tuple)
> >> # Union
> >> qunion = qset1.union(qset2)
> >> # Intersection
> >> qintersection = qset2.intersection(qset1)
> >> # Get shapes from the intersection
> >> for member in qintersection:
> >> layer.getShape(member[0], member[1])
> >> Sets are a first class type in the upcoming Python 2.4, well worth
> >> learning.
> >> cheers,
> >> Sean
> >> Sean Gillies
> >> sgillies at frii dot com
> >> http://users.frii.com/sgillies
> > Sean,
> > Thanks for the reply. Your solution is what I've essentially been
> > doing for
> > a while now in PHP. But this sort of thing is MUCH more
> useful when
> > you are
> > able to do a saveQuery. For example:
> > 1.) User searches by Attributes: [NAME] = 'Smith'. Query1.qy is
> > saved and
> > the file name is passed to the user along with a map showing all
> > highlighted
> > features.
> > 2.) User clicks the "AND" selection method and draws a box on the
> > map. The
> > box extent and the query file name are passed back. I do a
> > queryByRect on
> > the layer using the box to get result set1. I load in the
> old query
> > (set2).
> > I check the selection method and perform the relate
> (AND,OR,XOR) and
> > produce
> > set3 (JUST AS YOU HAVE DESCRIBED ABOVE). I save this as query2.qy,
> > load it
> > into the mapb object, drawQuery and spit back results. Now
> only those
> > features with Name = Smith AND inside the box are displayed.
> > 3.) User searches by Attributes: [YEARBUILT] < 1970 with selection
> > method
> > again set to AND which will further narrow the selection...
> > ...and this can go on and on indefinitely. This is the
> only way to do
> > multiple and successive spatial and attribute queries in order to
> > refine a selection set.
> > THIS IS GIS BABY!
> Adam, I didn't understand that you were using drawQuery ...
> that changes the equation a bit.
> > And here's why my interface wouldn't work with your solution above:
> > 1.) Iterating through large selection sets using mapscript
> to build
> > an array, or set, or whatever is too slow. I know this to
> be true in
> > PHP after doing a number of tests, and I can't say for sure
> in Python,
> > but I suspect
> > so. It is MUCH faster to do map.saveQuery to a file, and
> then write a
> > little routine to read the binary file into an array. This seemed
> > counter-intuitive to me, but I ran a bunch of tests and
> that's what I
> > found.
> > Much faster!
> Yes, getting query results one by one with mapscript is the slowest
> possible method. In my opinion, what's *really* needed is a
> mapscript
> method
> that returns arrays, or Python lists, of results. Then you wouldn't
> have to
> write/read from the filesystem either. Faster yet.
> > 2.) At the end of your solution you have an array of indexes but
> > nothing to
> > do with them but get the shape. What are you going to do with the
> > shapes,
> > draw each one? That's way to slow. What you need is a way
> to define
> > the
> > resultCache with your array, but queryByIndex is not implemented.
> > And, as I
> > said before, even if it was implemented, iterating though a
> large set
> > and
> > using queryByIndex on each index is WAY TO SLOW! It is
> MUCH faster to
> > dump
> > that new set to a file and do a map.loadQuery.
> Agreed, drawing individual shapes is slow.
> > And if you build shapefiles (or entirely new files in
> whatever format
> > you
> > prefer), as Lowell has suggested, you loose the initial
> indexing of the
> > original file and are no longer able to do successive spatial and
> > attribute
> > queries. You could use a FID attribute, but then you'd be back to
> > iterating
> > through a bunch of queryByAttributes...ugggh!
> > Please let me know what you think about this.
> > I don't know C, I'm on Windows, and I don't even compile my own
> > mapscript so
> > I'm really just using the software and not contributing to it's
> > development.
> > In light of that, if there is any way I can help with this,
> I am more
> > than
> > willing to put in the time. Let me know.
> > Best regards,
> > Adam
> You use hobu's mapscript, right? So you are asking for an enhancement
> to mapserver 4.3/4.4? I think a fully functional saveQuery/loadQuery
> is a very reasonable request. Please confirm, and I'll add
> an issue to
> Bugzilla.
> cheers,
> Sean
> Sean Gillies
Yes, I'm using hobu's mapscript, and Yes, I confirm! saveQuery is already
implemented (at least it's working fine on my side) hence my confusion when
loadQuery was not recognized. If implementing loadQuery is feasible it
would be excellent. Thanks.
And, since INDEXQUERY is a CGI mode, is exposing (is this the right verb?)
the queryByIndex method feasible as well?
And while I'm on a roll, the superior future enhancements as you mentioned -
perhaps 'getCache' and 'setCache' methods - allowing us to manipulate the
sets in memory. That would be fantastic, though I suspect it's no small
task.
Thanks again,
Adam
