reprojecting WMS layer
Thomas Chesky
thomaschesky at YAHOO.COM
Thu Sep 30 14:25:14 EDT 2004
Hello,
I am still having the problem of reprojecting WMS layers into other projection.
USGS provides it's Urban color ortho coverage only in epsg:4326 and I would like it to be in either local UTM zone or local state plate.
I have wms_srs set and PROJECTION tag set to 4326 at the layer level and output projection set via the cgi interface (a method which works fine with reprojecting shape files) The 2 output image is almost identical. There is a small "rotation" effect visible if I switch back and forth from the 2 images, but when I overlay a shapefile layer on it (which is correctly reprojected) the original projection 4326 creates a nicely overlayed image, while the reprojected one has the WMS and shape layer messed up, they do not correctly overlay.
Can I send 2 jpg attachment to the list to demonstrate?
The question therefore: is there any known trick with reprojecting WMS raster layer as opposed to locally stored raster and shape layer? Did anybody has this problem before?
Help me out on this as I am stucked for weeks already.
Here is my mapfile:
MAP
NAME USGSUrban
SHAPEPATH "/usr/local/mapdata/"
SIZE 600 400
IMAGETYPE PNG24
IMAGECOLOR 0 0 0
WEB
IMAGEPATH /usr/local/httpd/htdocs/tmp/
END
LAYER
NAME "SanFrancisco01"
TYPE RASTER
PROJECTION
"init=epsg:4326"
END
STATUS OFF
CONNECTION "http://gisdata.usgs.net:80/servlet/com.esri.wms.Esrimap/USGS_EDC_Ortho_133Urban?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "SanFrancisco01"
"wms_server_version" "1.1.0"
"wms_formatlist" "image/png,image/jpeg"
"wms_format" "image/png"
END
END
END
The 2 url which should generate to different projection of the WMS layer is:
mapserv?mode=map&map=/usr/local/mapapp/map.map&layer=SanFrancisco01&mapext=-122.226813776775+37.4764381661621+-122.213167520107+37.4835588561656&mapsize=600+400&map_projection=init%3Depsg:26910
mapserv?mode=map&map=/usr/local/mapapp/map.map&layer=SanFrancisco01&mapext=-122.226813776775+37.4764381661621+-122.213167520107+37.4835588561656&mapsize=600+400&map_projection=init%3Depsg:4326
Let me know if anyone has some idea of what's going wrong here.
Thanks
Thomas
Do you Yahoo!?
Express yourself with Y! Messenger! Free. Download now.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040930/d9709b11/attachment.html
