Is it possible to change the legend template via map_legend_template?
Ryan Grant ryangrant at GMAIL.COM
Thu Sep 30 16:11:41 EDT 2004
Turns out it was a stupid coding mistake..   It now works as expected. Thanks!
On Thu, 30 Sep 2004 15:59:44 -0400, Daniel Morissette
<dmorissette at dmsolutions.ca> wrote:
> Ryan Grant wrote:
> > In the form I initially submit to load my mapserver interface, if I add this:
> > <INPUT type="hidden" name="map_legend_template" value="../legend_display.html">
> > Mapserver crashes out when it gets to the [legend] section of my
> > template. Can the legend be dynamically set like this?
> I can't see any reason to explain the crash. Perhaps you should test
> against against 4.3, and if it still crashes then please file a bug with
> a complete testcase to reproduce the crash.
>  Daniel Morissette               dmorissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
