Problems w/ MapScript C#
    Ian Erickson
    ierickson at ANALYGIS.COM
    Sun Apr  3 20:49:59 PDT 2005
I've successfully built the C# Mapscript assembly, and have successfully
written code that generates an image file to disk.  Everything seems to
work just fine until I make repeated calls to the map.draw() function.
I get the following exception after 3 or 4 calls to the private member
function drawMapImage():
System.NullReferenceException: Object reference not set to an instance
of an object.
   at mapscriptPINVOKE.mapObj_draw(IntPtr jarg1)
   at mapObj.draw()
   at SimpleMap.Form1.drawMapImage()
My drawMapImage() member looks like this:
        private void drawMapImage()
            try
                m_img = m_map.draw();
                m_img.save(@"E:\Web\Data\console.png", m_map);
                Console.WriteLine("Image saved!");
            catch (Exception e)
                Console.WriteLine("Exception:\n" + e);
The contstructor for this form contains the two following lines:
            m_map = new mapObj(@"E:\Web\Data\road.map");
I've got no idea of where to go from here.  I've tried local definitions
of the m_map and m_img objects and explicitly disposing them.  I've even
forced the System.GC.Collect() method in an attempt to clean any unused
objects up.  Does anyone have a clue as to where to go from here?
Ian Erickson
AnalyGIS, LLC
More information about the MapServer-users
