Problems w/ MapScript C#
Sean Gillies
sgillies at FRII.COM
Thu Apr 7 09:42:43 EDT 2005
On Apr 7, 2005, at 3:30 AM, Johannes Schulte Sÿfffffcdhoff wrote:
> --- Sean Gillies <sgillies at FRII.COM> wrote:
>> On Apr 6, 2005, at 3:59 PM, Morten Nielsen wrote:
>>>> I've successfully built the C# Mapscript
>> assembly, and have
>>>> successfully
>>>> written code that generates an image file to
>> disk. Everything seems
>>>> to
>>>> work just fine until I make repeated calls to the
>> map.draw() function.
>>>> I get the following exception after 3 or 4 calls
>> to the private member
>>>> function drawMapImage():
>>>> System.NullReferenceException: Object reference
>> not set to an instance
>>>> of an object.
>>>> at mapscriptPINVOKE.mapObj_draw(IntPtr jarg1)
>>>> at mapObj.draw()
>>>> at SimpleMap.Form1.drawMapImage()
>>> I have lately experienced the same problem that
>> Ian has. It seems that
>>> the
>>> C#/SWIG mapscript is very unstable, no matter
>> whether it's a Windows
>>> Application or a web application. Some times it
>> works, sometimes it
>>> don't.
>>> Sometimes it always works on one machine, but
>> never on another. And
>>> sometimes it even crashes the IIS process. I
>> wonder if this also
>>> occurs on
>>> the Mono-based assemblies.
>>> The C# support in SWIG is pretty new, so it could
>> be a SWIG bug, but I
>>> wasn't ably to find any that apply in their
>> bug-tracking. Perhaps we
>>> should
>>> better start looking at the SWIG implementation,
>> although I really
>>> wouldn't
>>> know where to begin; especially because it's so
>> hard to debug.
>>> Pointers to get me started on this are highly
>> appreciated.
>>> /Morten Nielsen
>> My impression is that you may be getting ahead of
>> yourselves a bit with
>> your SimpleMap and Form classes. Let's back up a
>> bit. Make the
>> simplest possible mapscript application, and then
>> run the web app under
>> your debugger to find out what the problem actually
>> is. If you can't
>> debug your website, perhaps try with some sort of
>> lightweight
>> multithreading HTTP server. The .NET platform must
>> have something like
>> this.
>> That said, now I am going to take a wild swing :)
>> Any chance that
>> you've overlooked building in the win32 thread
>> support from
>> mapthread.c? It's off by default in MapServer's
>> windows makefile and
>> never really mentioned in any of the win32
>> installation docs.
> Just another wild swing :-). Morten is using the
> windows binary of the gd library. Doing this you have
> to compile everything with VC6 and you have to bind
> the multithreaded dll crt. see the gd faq for more
> information
> /Johannes
Right. Good point, Johannes.
Sean
