Install/Config Problems
Jeffrey Johnson ortelius at GMAIL.COM
Mon Apr 11 13:36:47 EDT 2005
I ended up getting everything to work correctly by compiling PHP as an
Apache DSO using this configure syntax. (Also had to move the various
GD pieces into a single directory)
./configure --prefix=/usr/local/php
--with-apxs=/usr/local/apache/bin/apxs --with-pgsql --enable-dbase
--with-freetype=/usr/local/include/freetype2/ --with-jpeg=/usr/lib/
--with-gd=/usr/src/gd
On Apr 10, 2005 10:08 PM, Giridhar Manepalli <gmanepal at gmail.com> wrote:
> Hello,
> Just to keep this thread resourceful for later:
> I compiled php without GD. I also used the regex from php sources.
> Debugging that only helped me learn that, it went onto some infinite
> loop, I specifically did not observe any library miss-calls!
> Regards,
> Giridhar
> On Apr 10, 2005 8:05 PM, Morten Hulden <morten at untamo.net> wrote:
> > Giridhar Manepalli wrote:
> > > I was successful in installing Mapserver with php mapscript on Fedora Core 2.
> > > Php version 4.3.10
> > > If anyone need any help regarding this configuration, I can help. I
> > > guess, there is something with Fedora Core 3 that developers of
> > > Mapserver need to look at!
> > I do not see this a FC3 specific problem, I think it happens whenever
> > PHP is compiled with the bundled GD library. The php_ prefix to GD
> > function names was introduced to the bundled GD package in PHP last
> > summer in order to prevent name space conflicts with other apache
> > modules that use GD, such as perl.
> > Now if PHP uses the bundled GD, mapserver 4.4.1 will still compile if I
> > point to external GD libs, but compilation of PHP_mapscript will fail.
> > On the other hand, if I try to trick mapscript to compile against PHP's
> > bundled GD then I get segfault at mapscript dl-time.
> > Could something similar to --with-php-regex-dir in mapserver configure
> > scripts solve this?
> > Of course recompiling PHP with external GD is an option, but then I am
> > out out sync with FC3 update packages, which means increased maintenance
> > burden.
> > >>>Currently, I am trying to install on Fedora Core 3, with php-4.3.11.  > I built it as a DSO similar to the working model.
> > >>If you get mapscript 4.4.1 to work on plain Fedora Core 3 I am
> > >>interested to know how you get around the fact that FC3 comes with a PHP
> > >>that has a bundled GD version where function names have a php_ prefix
> > >>that mapscript will not recognize.
> > >>Even if compile succeeds after some tricks, dl() segfaults because of
> > >>undefined symbols.
> > >>Recompiling PHP to use external GD seemed to be the only option last I
> > >>tried, but that was a while ago...
> > >>rgds
