shp2tile question
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Apr 11 15:28:45 EDT 2005
Hi Don,
check the dbf of your generated tileindex (the LOCATION field). I usually
use absolute paths in there. Are there absolute or relative paths to the
files in there?
Also use TYPE POLYGON. Are you zoomed in enough to have your layer showing
up, since you are using a MAXSCALE setting?
Best regards,
Bart
On Mon, 11 Apr 2005 15:24:45 -0400, Don Deskins <dldeskins at gmail.com>
wrote:
> Bart (and Steve),
> Thanks.
> I have my files created and tried to reference this index in my map file:
> # parcels
> LAYER
> NAME 'tileindex'
> TYPE TILEINDEX
> DATA '/path/to/tileindex'
> MAXSCALE 40000
> END
> LAYER
> NAME 'SCAP_Cert2004_ParcelsUTM16M'
> STATUS ON
> TYPE POLYGON
> TILEINDEX '/path/to/tileindex'
> #TILEITEM 'LOCATION'
> MAXSCALE 40000
> END
> I get no error but my shapes are not showing up... do you see a
> problem with the above map?
> Don
> On Apr 11, 2005 2:58 PM, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
>> Hi,
>> It is tile4ms, not tile2ms, probably a typo by Steve.
>> It is a Mapserver utility to make a tileindex. Alternatively, you can
>> also
>> use ogrtindex for vector layers and gdaltindex for raster layers.
>> Best regards,
>> Bart
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
