Search returned no results
Sean Gillies
sgillies at FRII.COM
Sun Apr 17 12:00:32 EDT 2005
You need to define query templates for your layers. Any value will do.
I like to do something like this:
LAYER
TEMPLATE "MapServers developers are a bit sadistic and insist on
hazing new users with this poorly documented control over
query-ability. How many user hours have been lost to this gotcha?
I'll bet it's many thousands."
END
cheers,
Sean
On Apr 17, 2005, at 9:02 AM, Jeffrey Johnson wrote:
> Nope. I tried values up to 100 and no luck. The polygon layer covers
> nearly all of the map area, so this shouldn't a problem. I am also
> having trouble getting the legend to work. An image seems to be
> generated, but its empty. Is there something wrong with my mapfile
> that allows the map to be generated, but other modules not to work?
> Thanks,
> Jeff=20
> On 4/17/05, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
>> =20
>> Try setting tolerance in the LAYER object (i.e. TOLERANCE 10).
>> =20
>> ..Tom
>> =20
>> =20
>>> -----Original Message-----
>>> From: UMN MapServer Users List
>>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jeffrey Johnson
>>> Sent: Sunday, 17 April, 2005 09:36
>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>> Subject: [UMN_MAPSERVER-USERS] Search returned no results
>>> I'm having trouble getting query mode to work in my first
>>> mapserver application. The standard "msQueryByPoint(): Search
>>> returned no results. No matching record(s) found. " is
>>> returned. The map file and template seem pretty simple and
>>> straightforward. I checked that img.x and img.y are being
>>> passed. Not sure whats up. Any ideas?
>>> Jeff
>>> ----Map File-----
>>> MAP
>>> NAME SDNHMPaleo
>>> STATUS ON
>>> SIZE 800 600
>>> EXTENT 6150763 1775304 6613436 2129759
>>> UNITS METERS
>>> SHAPEPATH "/home/www/sdnhmpaleo/data"
>>> IMAGECOLOR 230 230 230
>>> SYMBOLSET 'symbols.sym'
>>> FONTSET "fonts/fonts.list"
>>> DEBUG ON
>>> IMAGETYPE PNG
>>> WEB
>>> HEADER 'header.html'
>>> FOOTER 'footer.html'
>>> TEMPLATE 'map.htm'
>>> IMAGEPATH '/home/www/sdnhmpaleo/temp/'
>>> IMAGEURL '/sdnhmpaleo/temp/'
>>> MINSCALE 50000
>>> MAXSCALE 5000000
>>> LOG '/home/www/sdnhmpaleo/sdnhmpaleo.log'
>>> END
>>> SCALEBAR
>>> IMAGECOLOR 255 255 255
>>> LABEL
>>> COLOR 0 0 0
>>> SIZE TINY
>>> END
>>> STYLE 1
>>> SIZE 300 10
>>> COLOR 0 0 0
>>> UNITS MILES
>>> INTERVALS 2
>>> TRANSPARENT FALSE
>>> STATUS EMBED
>>> POSITION LR
>>> END
>>> LAYER
>>> NAME geology
>>> DATA cal-geol2
>>> STATUS OFF
>>> TYPE POLYGON
>>> CLASSITEM 'ptype'
>>> LABELITEM 'ptype'
>>> CLASS
>>> EXPRESSION 'water'
>>> COLOR 190 232 255
>>> OUTLINECOLOR 0 0 0
>>> END
>>> CLASS
>>> EXPRESSION 'Q'
>>> COLOR 255 255 179
>>> OUTLINECOLOR 0 0 0
>>> END
>>> *** More classes here ***
>>> END
>>> LAYER
>>> NAME roads
>>> DATA SD-Freeways2
>>> STATUS OFF
>>> TYPE LINE
>>> CLASS
>>> COLOR 0 0 0
>>> END
>>> END
>>> LAYER
>>> NAME localities
>>> DATA localities
>>> STATUS OFF
>>> TYPE POINT
>>> CLASS
>>> SYMBOL 'circle'
>>> COLOR 255 0 0
>>> MINSIZE 5
>>> END
>>> END
>>> END
>>> ----End Map File-----
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
