Display a map using Tiger data
Ryan D Taylor
ryant at CS.UTAH.EDU
Tue Apr 19 16:15:24 EDT 2005
Just an update. You were right about the extent info. I put in the
output from ogrinfo -ro -so -al and it works beautifully. Thank you so
much.
Ryan T.
On Tue, 19 Apr 2005, Frank Warmerdam wrote:
> On 4/19/05, ryan <ryant at cs.utah.edu> wrote:
> > Hi,
> > I'm having trouble displaying a map of street data i got from the tiger LINE
> > project. mapserv doesn't give me any errors, just shows a blank png. I can
> > run the demo stuff fine. I've also tried changing STATUS from ON to OFF to
> > DEFAULT in my mapfile. Also, I don't know for sure what the extent of my
> > map should be, but i'm passing 1.00, 1.00, 50000.00, 50000.00 because i can
> > use arcexplorer on my windows machine to find that the dimensions of the map
> > are about 50Km by 50Km.
> Ryan,
> I would suggest the issue is extents related. Likely all your vectors are
> getting drawn in one pixel. I would suggest you use some utility to get
> the extents of your dataset in their intrinsic coordinate system which would
> be lat/long if they are tiger/line data (that hasn't been reprojected).
> For shapefiles and a few other formats, you could use ogrinfo.
> eg.
> ogrinfo -ro -so -al abc.shp
> > Here is the web address i access:
> > http://localhost/cgi-bin/mapserv?map=/usr/bin/apache/htdocs/mapserver/simple.map&mode=map&layer=Freeways&mapext=1.00%201.00%2050000.00%2050000.00&imgsize=300%20300
> > And my map file is here:
> > #-------start of map file---------------#
> > NAME sampleMapServer
> > # the below extents and size are provided in the URL and so must be removed
> > #EXTENT 482925.85 3625874.39 497393.16 3617143.43
> Note, just because you are listing the extents in the url doesn't
> mean you have to remove them from the map. The info passed in
> the url just overrides the info in the map file. I generally try to fill
> out reasonable information in the mapfile so I can use utilities like
> shp2img for debugging purposes.
> PS. there are lots of possible reasons your map could be failing to draw
> besides the extents issue, but it is pretty hard for us to remotely debug
> without all supporting files, and a clear understanding of what version
> of mapserver you are running. Generally "mapserv -v" output is more
> useful than your configure line.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
