SWF OUTPUT_MOVIE=SINGLE resolution?
Chris Hackel
cvhackel at YAHOO.COM
Wed Apr 20 14:39:05 EDT 2005
No.. there's no labels in that layer.
Just to test, I changed the mapfile below to:
LAYER
NAME Complete_Chain
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION
"/Library/WebServer/Documents/tigertest/tgr36061"
CLASS
COLOR 153 102 0
LABEL
TYPE TRUETYPE
FONT arial-bold
END
END
END # Layer
and it still doesn't work.
Any ideas?
Thanks,
Chris
--- Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> wrote:
> Chris,
> Is this a problem with layers containing labels ?
> Can you disable
> layers with labels and try it again with
> OUTPUT_MOVIE=SINGLE ?
> Basically if you want to use OUTPUT_MOVIE=SINGLE,
> you need to use true
> type fonts instead of FDB fonts as explained in the
> post.
> Later,
> Chris Hackel wrote:
> > Outputting SWF, when I set OUTPUT_MOVIE=SINGLE I
> get
> > an empty movie. When it's MULTIPLE it works fine.
> This
> > problem was described here:
http://lists.gis.umn.edu/pipermail/mapserver-dev/2004-June/001112.html
> > but I could not find any sort of resolution. I'm
> using
> > mapserver 4.4.2.
> > Any assistance would be much appreciated!
> > Thank you,
> > Chris
> > Full file:
> > MAP
> > EXTENT -74.047185 40.679548 -73.907005
> 40.882078
> > SIZE 400 300
> > PROJECTION
> > "init=epsg:4269"
> > END
> > WEB
> > TEMPLATE "tigermap.html"
> > IMAGEPATH
> > "/Library/WebServer/Documents/tigertest/tmp/"
> > IMAGEURL "/tigertest/tmp/"
> > END
> > OUTPUTFORMAT
> > NAME swf
> > DRIVER "SWF"
> > MIMETYPE
> "application/x-shockwave-flash"
> > EXTENSION "swf"
> > IMAGEMODE PC256
> > FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> > END
> > IMAGETYPE swf
> > LAYER
> > NAME Complete_Chain
> > TYPE LINE
> > STATUS DEFAULT
> > CONNECTIONTYPE OGR
> > CONNECTION
> > CLASS
> > COLOR 153 102 0
> > END
> > END # Layer
> > END
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
