HPGN Datum? (fwd)
Bill Binko
bill at BINKO.NET
Mon Apr 25 22:40:23 EDT 2005
On Mon, 25 Apr 2005, Dean C. Mikkelsen wrote:
> Hi Bill,
> Have you applied the PROJECTION to the LAYER level on the .map file?
I have, but I've been using the init=epsg instead of the actual
parameters...
> What we are experiencing is the old NAD27/NAD83 problem. If PROJ.4 is
> installed correctly, with the NADCON files, there should be no problem.
> What does your .map file look like?
The relavent portions (I believe) are below. There are several layers of
each projection (as well as some others). However, these two are the ones
that I'm having trouble with.
I'm beginning to wonder if that epsg:26759 really lines up with the
parameters: perhaps I should put them in "by hand".
Thanks
Bill
MAP
UNITS METERS
EXTENT -83.16 27.62 -81.81 28.18
PROJECTION
"init=epsg:26759"
END
LAYER
PROJECTION
"init=epsg:26759"
END
NAME "AllParcels"
TYPE POLYGON
STATUS DEFAULT
MAXSCALE 150000
DATA "Parcel_polygons_NAD27"
CLASS
NAME "Parcels"
OUTLINECOLOR 150 150 150
COLOR 220 220 200
SYMBOL 0
END
END
LAYER
NAME "Roads"
TYPE LINE
STATUS ON
PROJECTION
"+proj=aea"
"+lat_1=24"
"+lat_2=31.5"
"+lat_0=24"
"+lon_0=-84"
"+x_0=400000"
"+y_0=0"
"+ellps=GRS80"
"+datum=NAD83"
"+units=m"
"+no_defs"
END
DATA "tgrr0052"
LABELITEM "FENAME"
CLASS
NAME "Roads"
COLOR 200 200 200
SYMBOL 0
LABEL
TYPE TRUETYPE
ANGLE AUTO
#ANTIALIAS true
color 0 0 0
OUTLINECOLOR 255 255 255
FONT arial
SIZE 10
MINFEATURESIZE 40
END
END
END
END
> Cheers,
> Dean
> Dean C. Mikkelsen,B.Sc.,P.Eng.
> Principal Consultant
> Terra ETL Ltd. - Consultants on GIS & Geodesy
> Vancouver, B.C., Canada
> Phone: 604-929-8630
> E-mail: dcmikkelsen at shaw.ca
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Bill Binko
> Sent: April 25, 2005 8:35 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] HPGN Datum? (fwd)
> Once again forgot to cc the list: sorry
> ---------- Forwarded message ----------
> Date: Mon, 25 Apr 2005 11:21:27 -0400 (EDT)
> From: Bill Binko <bill at binko.net>
> To: Dean C. Mikkelsen <dcmikkelsen at shaw.ca>
> Subject: RE: [UMN_MAPSERVER-USERS] HPGN Datum?
> On Sun, 24 Apr 2005, Dean C. Mikkelsen wrote:
> > Hi Bill,
> > Sure, feel free to post them to the board. I'll take a look.
> > Cheers,
> > Dean
> Here are the two projections that are giving me fits (from the shapefile
> .prj files). When I place them on the same map, they simply don't line
> up.
> From FGDL (HARN projection):
> PROJCS["Albers Conical Equal Area (Florida Geographic Data Library)",
> GEOGCS["GCS_North_American_1983_HARN",DATUM["D_North_American_1983_HARN"
> SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],PROJECTION["Albers"],
> PARAMETER["False_Easting",400000.0],PARAMETER["False_Northing",0.0],
> PARAMETER["Central_Meridian",-84.0],PARAMETER["Standard_Parallel_1",24.0
> PARAMETER["Standard_Parallel_2",31.5],PARAMETER["Central_Parallel",24.0]
> ,UNIT["Meter",1.0]]
> From the Pinellas County Data ("Florida West") which I've been using
> epsg:26759:
> PROJCS["NAD27 Florida State Planes, Western Zone, US Foot",
> GEOGCS["North_American_Datum_1927",DATUM["D_North_American_1927",
> SPHEROID["Clarke -
> 1866",6378206.4,294.9786982139006]],PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",24.3333333333333],PARAMETER["central_meri
> dian",-82],
> PARAMETER["scale_factor",0.9999411765],PARAMETER["false_easting",500000]
> PARAMETER["false_northing",0],UNIT["Foot_US",0.3048006]]
> Thanks
> Bill
