Extent and Shapefiles
Matthew Roberson
matt at MSILEADS.COM
Tue Apr 26 15:39:16 EDT 2005
First, let me just say I just started using MapServer this week and I
am sort of confused by all the different ways maps can be projected.
When i use ogrinfo, to determine the Extent of a shapefile(in this case
the zipcode boundries for the state of Missouri), how do I know what
units the values are in?
Is the minx value below -95.774704 meters, feet, or something else?
Or maybe the minx value is expressed in degrees, minutes, seconds. How
can I tell?
Below is what output from ogrinfo on the aforementioned shapefile.
Thanks,
Matt
[imac-dev03:WebServer/Documents/data] matthewr% ogrinfo -al -so
zt29_d00.shp zt29_d00
INFO: Open of `zt29_d00.shp'
using driver `ESRI Shapefile' successful.
Layer name: zt29_d00
Geometry: Polygon
Feature Count: 1341
Extent: (-95.774704, 35.995683) - (-89.098843, 40.613640)
Layer SRS WKT:
(unknown)
AREA: Real (20.5)
PERIMETER: Real (20.5)
ZT29_D00_: Integer (11.0)
ZT29_D00_I: Integer (11.0)
ZCTA: String (5.0)
LSAD: String (2.0)
LSAD_TRANS: String (50.0)
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050426/c98c9a76/attachment.bin
