GIF Raster Image Process Problem {Scanned}
Siki Zoltan siki at AGT.BME.HU
Fri Apr 29 04:31:00 EDT 2005
Dear Akio,
You should define EXTENT, UNITS and SHAPEPATH at separate lines.
Do you have world file to your image? Check the extents.
Try STATUS DEFAULT.
Bye Zoltan
On Fri, 29 Apr 2005, Akio Neuchi wrote:
> Hello to all,
> I am still quite new working with MapServer, and this is my first time to
> process a Raster Image, especially with GIF files. My Vector Layers work
> fine on MAP file.
> I tried the following definition with every combination of parametres, and
> the result was Null, just a shade appeared without image.
> I have PostGre, Proj, GD, etc. and GDAL(v1.1.9) enabled on ./config, and the
> world file is created with proper coordinate.
> Am I doing something basically wrong? Is this a question of ./config,
> missing something else?
> Please let me have your advices. Thanks in advance for your help.
> Akio Neuchi
> MAP
> NAME rastest
> STATUS ON
> SIZE 600 700
> EXTENT 121.938889 23.442222 149.500001 46.466666 UNITS dd SHAPEPATH "data"
> FONTSET "./fonts/fonts.lst"
> #SYMBOLSET "/var/www/html/zoom2it_mapserver/map_symbols/symbols.sym"
> IMAGECOLOR 225 240 200
> DEBUG ON
> IMAGETYPE GIF
> #IMAGETYPE PNG
> #IMAGETYPE JPEG
> #IMAGEQUALITY 400
> WEB
>         EMPTY "/gistest/empty.html"
>         HEADER decide_route_header.html
>         TEMPLATE decide_route.html
>         FOOTER decide_route_footer.html
>         MINSCALE 0
>         MAXSCALE 1500000000
>         IMAGEPATH
> /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/tmp
>         IMAGEURL /gistest/tmp
>         LOG
> /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/rastest.log
> #       TEMPLATE "decide_route.html"
>         METADATA
>                 WMS_TITLE "Raster Map Display Demo"
>                 WMS_ABSTRACT "Created by TCI"
>                 WMS_ACCESSCONSTRAINTS none
>         END
> END
> QUERYMAP
>         SIZE 200 200
>         STATUS ON
>         STYLE HILITE
>         COLOR 255 0 0
> END
> OUTPUTFORMAT
>      NAME gif
>      MIMETYPE "image/gif"
>      DRIVER "GD/GIF"
>      EXTENSION "gif"
>      IMAGEMODE PC256
> #     TRANSPARENT FALSE
> #     FORMATOPTION "INTERLACE=OFF"
> END
> OUTPUTFORMAT
>      NAME png
>      MIMETYPE "image/png"
>      DRIVER "GD/PNG"
>      EXTENSION "png"
>      IMAGEMODE PC256
> #     TRANSPARENT FALSE
> END
> OUTPUTFORMAT
>      NAME jpeg
>      MIMETYPE "image/jpeg"
>      DRIVER "GD/JPEG"
>      EXTENSION "jpg"
>      IMAGEMODE RGB
> #     TRANSPARENT FALSE
> END
> # RASTER Layer
> LAYER
>         NAME "RAS365313"
>         GROUP "B_RASTER"
>         TYPE RASTER
>         STATUS ON
> #       STATUS DEFAULT
> #       TOLERANCE 5
> #       TOLERANCEUNITS PIXELS
> #       OFFSITE 0 0 0
>         OFFSITE 169 109 154
> #       DATA "MS12000DEF365313.png"
> #       DATA "MS12000DEF365313.jpeg"
>         CLASS
>         COLOR 225 200 100
>         END
>         DUMP TRUE
>         DEBUG ON
> END
> END # Map File
