PROJ.4 epsg file
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri Apr 29 12:35:51 EDT 2005
On 4/29/05, Obe, Regina DNDMIS <robe.dnd at cityofboston.gov> wrote:
> Is there any way to explicitly specify the location of the epsg file used by
> the mapserver cgi projection library without using the PROJ_LIB environment
> variable?
Regina,
You can place the line "CONFIG PROJ_LIB /abc/def" in your mapfile
or rebuild PROJ.4 to use an alternate package data directory (see
configure switches).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
