ClickToPoint with projection
Jeff Portwine jdport at VERITIME.COM
Mon Aug 1 12:00:09 EDT 2005
What I do , is I convert to lat/long the same way you did, and then put the
results in a point object and re-project that point to the mercator instead
of converting from click coordinates directly to mercator.
It seems to work ok...
-Jeff
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, August 01, 2005 11:53 AM
Subject: [UMN_MAPSERVER-USERS] ClickToPoint with projection
I am having problems with translating click coordinates to map
coordinates in mapscript/PHP.  I have written a simple function which
converts click coords to map coords based on a flat (lat/long)
projection and it works well.  However, I have now decided to use a
mercator projection and, of course, the method no longer works
correctly.
Has anyone written a PHP function to convert from image coordinates to
map coordinates when a mercator projection is used?
If not, can anyone tell me where to look for help!
Very best to all,
Dan
Dan Taylor
Software Development Engineer, JTL Systems Ltd
PhD Student, Reading University, UK
http://www.logicalgenetics.com
