Error making mapscript tcl
Philip Dillon-Thiselton dibblethewrecker at JIWE.ORG
Mon Aug 1 12:35:48 EDT 2005
OK - I hurdled that little problem - mapserver-workbench then wanted
mkWidgets, i fixed that ok but now...
[mapserver-workbench] : msedit.tcl
Error in startup script: can't find package msTclObjs
    while executing
"package require msTclObjs"
    (file "/usr/bin/msedit.tcl" line 23)
I can't even find msTclObjs mentioned on teh net except for on the
mapserver related sites - what is it?
Phil
Nikos wrote:
> Philip Dillon-Thiselton wrote:
>> I'm just trying to get this set up so I can use mapscript-workbench -
>> any help appreciated!
> Hi Philip,
> FWIW, I believe if you compile/link against tcl8.3, you should have no
> problems...
> I've ran into this also, but have not had time to look into it..
> ANyway, you can compile/link against 8.3 and use it under
> tcl8.4.....The problem is just the hassle of downloading the 8.3
> sources...
> regards,
> nicolas boretos
