Expression not working on mapserver
Lego han (aka Doig)
legoist at GMAIL.COM
Mon Aug 1 23:10:31 EDT 2005
Below I have a snippet of a map file... I get a blank image every
time I use the expression. If I comment it out everything appears.
When I run the query, I get data.... What's the problem here? I've
tried Quotes, no Quotes, all sorts of iterations.
Help...
DATA "the_geom from (SELECT the_geom,CASE WHEN cfcc IN
('A11','A12','A13','A14','A15','A16')
THEN 'freeway' ELSE 'road' END as roadtype,cfcc,
fename,oid FROM roads) as foo USING unique oid"
TYPE LINE
STATUS ON
CLASS
EXPRESSION "([roadtype] = 'freeway')"
STYLE
COLOR 55 50 0
OUTLINECOLOR 200 200 200
SYMBOL 0
MINSIZE 3
SIZE 5
END
END
CLASS
EXPRESSION ([fename] = 'Monroe')
STYLE
COLOR 255 0 0
SYMBOL 0
SIZE 3
END
END
