Expression not working on mapserver
Lego han (aka Doig)
legoist at GMAIL.COM
Tue Aug 2 10:49:42 EDT 2005
Thanks. I actually got the quote issues worked out. It looks like
this: EXPRESSION ('[roadtype]' = 'freeway')
now. Quoting column names just doesn't come naturally to me.
On 8/1/05, Steve Lime <steve.lime at dnr.state.mn.us> wrote:
> There are 2 problems:
> 1) EXPRESSION "([roadtype] = 'freeway')" should be
> EXPRESSION ([roadtype] = 'freeway')
> No qoutes around the logical expression otherwise MapServer treats the whole thing as one big string.
> 2) EXPRESSION ([roadtype] = 'freeway') should be
> MapServer doesn't know anything about item types or anything so you must be overly explicit when preparing expressions. Same applies to the rest of your mapfile.
> Steve
> >>> "Lego han (aka Doig)" <legoist at GMAIL.COM> 08/01/05 10:10 PM >>>
> Below I have a snippet of a map file... I get a blank image every
> time I use the expression. If I comment it out everything appears.
> When I run the query, I get data.... What's the problem here? I've
> tried Quotes, no Quotes, all sorts of iterations.
> Help...
> DATA "the_geom from (SELECT the_geom,CASE WHEN cfcc IN
> ('A11','A12','A13','A14','A15','A16')
> THEN 'freeway' ELSE 'road' END as roadtype,cfcc,
> fename,oid FROM roads) as foo USING unique oid"
> TYPE LINE
> STATUS ON
> CLASS
> STYLE
> COLOR 55 50 0
> OUTLINECOLOR 200 200 200
> SYMBOL 0
> MINSIZE 3
> SIZE 5
> END
> END
> CLASS
> EXPRESSION ([fename] = 'Monroe')
> STYLE
> COLOR 255 0 0
> SYMBOL 0
> SIZE 3
> END
> END
