problem with tiled layer
Ed McNierney ed at TOPOZONE.COM
Wed Aug 3 08:45:36 EDT 2005
David -
Is the server publicly accessible?  It would be helpful (but not
essential) to be able to see this behavior interactively.
I did notice that all your data come from MapInfo TAB files.  I don't
know if that's relevant, but while I've never seen this behavior myself
I also do not use TAB files for vector data.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Hunter, David - St. Louis Park, MN
Sent: Tuesday, August 02, 2005 6:49 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] problem with tiled layer
I was able to reproduce the problem using version 4.6.  I can send you a
.map file, data and GET strings that would show the problem, if you're
interested.
Behalf Of Frank Warmerdam
Sent: Tuesday, August 02, 2005 4:11 PM
On 8/2/05, Hunter, David - St. Louis Park, MN <David.Hunter at fnf.com>
wrote:
> Should I try and upgrade to 4.6?  What would be involved, merely
copying
> the contents of the bin directory to my cgi-bin?
David,
Well, that depends on your circumstances.  Where you get your binaries,
etc.  Generally speaking the .map file and other application components
should be pretty compatible between 4.4 and 4.6 so the main issue is
replacing your binaries and support libraries with a newer version.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
