problem with tiled layer
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Aug 3 09:08:20 EDT 2005
On 8/2/05, Hunter, David - St. Louis Park, MN <David.Hunter at fnf.com> wrote:
> I was able to reproduce the problem using version 4.6. I can send you a
> .map file, data and GET strings that would show the problem, if you're
> interested.
David,
That would be perfect. Also please setup a bugzilla bug report for
the issue, but you shouldn't attach all the data there if it is large.
Thanks,
and watch the world go round - Rush | Geospatial Programmer for Rent
