Phpmapscript.dll
vincent.dacol
vincent.dacol at LAPOSTE.NET
Wed Aug 3 10:05:57 EDT 2005
I have modified my configuration. Instead of IIS 6 I use
Apache 2. An other difference is that php run in cgi mode.
I call php_mapscrip_45 with the dl() fonction, and now, it
work with php 5.04
Thanks for the hand,
Bye,
Vincent
> I run under IIS without problems, but I use PHP 4.3.11.
> Best regards,
> Bart
> Bart van den Eijnden
> Syncera IT Solutions
> Postbus 270
> 2600 AG DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
> >>> "vincent.dacol" <vincent.dacol at laposte.net> 08/03/05
13:08 PM >>>
> OK, thanks for the answers.
> Before try with php_mapscript_46.dll, I have try
> php_mapscript_45.dll compiled for PhP5, but it didn't work.
> Maybe IIS server is the source of the problem??? I will try
> with apache 2.
> Any ideas are welcom ;)
> Best regard,
> Vincent
> > Normally it is called php_mapscript_46.dll (note the first
> underscore).
> > Where did you get the Mapscript binary from? For PHP5 it
> needs to be recompiled against PHP 5.
> > Best regards,
> > Bart
> > Postbus 270
> > 2600 AG DELFT
> > >>> "vincent.dacol" <vincent.dacol at LAPOSTE.NET> 08/03/05
> 11:38 AM >>>
> > I have put in php.ini:
> > The answers are bottom your questions.
> > > What exactly did you put in php.ini? What do you search for
> > in the phpinfo page, Mapscript?
> > extention=phpmapscript_46.dll
> > > Are there no errors reported by PHP with loading the
> > extension?
> > There are no error reported by php
> > Can all the dependent dll's be found?
> > this is the question ;) I don't no who're dependent dll, so I
> > have put a lot of them in my "ext" folder.
> > I'm under IIS (sorry, but I don't have the choice, and php5).
> > php5 work fine, IIS work has he can ;) (fine in fact)
> > My onlyest probleme is that I must use mapscript fonction, and
> > the extention doesn't appear when I do a phpinfo(), and IIS
> > could't use dl fonction :(((
> > Thanks for the help,
> > Best regards,
> > Vincent
> > > Best regards,
> > > Bart
> > > Postbus 270
> > > 2600 AG DELFT
> > 11:27 AM >>>
> > > Hi Bart,
> > > I have put the extention in php.ini.
> > > I couldn't do a dl in a script.
> > > Best regards,
> > > Vincent
> > > > Hi,
> > > > did you a do a dl of the Mapscript extension before
calling
> > > phpinfo? Or did you put the extension in php.ini to load by
> > > default?
> > > > Best regards,
> > > > Bart
> > > > Postbus 270
> > > > 2600 AG DELFT
> > > 10:30 AM >>>
> > > > Hello everyone,
> > > > I have a little strange probleme.
> > > > I want to use phpmapscript.dll in my php installation. I
> have
> > > > put the dll in the correct folder (ext) and my php.ini is
> > > > correctly configured.
> > > > But when I make a phpinfo(), phpmapscript doesn't
appeart on
> > > > the screen.
> > > > Anybody have had this problem? And how is it possible to
> > > > active this extention?
> > > > I only want to use this extention, not mapserver cgi.
> > > > Have a nice day,
> > > > Vincent
> > > > Accédez au courrier électronique de La Poste :
> > > www.laposte.net ;
> > > > 3615 LAPOSTENET (0,34/mn) ; tél : 08 92 68 13 50
(0,34/mn)
> > www.laposte.net ;
> > > 3615 LAPOSTENET (0,34/mn) ; tél : 08 92 68 13 50 (0,34/mn)
> www.laposte.net ;
www.laposte.net ;
Accédez au courrier électronique de La Poste : www.laposte.net ;
