problem with tiled layer
Hunter, David - St. Louis Park, MN David.Hunter at FNF.COM
Wed Aug 3 11:35:03 EDT 2005
No, unfortunately the server is locked down.  I suspect that the .TAB
format may have something to do with the problem, causing the
overlapping bounding boxes to be misinterpreted.
I will be zipping up the .map file, data and example URLs for Frank
Warmerdam.  Would you like a copy of that also?
-----Original Message-----
Sent: Wednesday, August 03, 2005 7:46 AM
To: Hunter, David - St. Louis Park, MN; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] problem with tiled layer
David -
Is the server publicly accessible?  It would be helpful (but not
essential) to be able to see this behavior interactively.
I did notice that all your data come from MapInfo TAB files.  I don't
know if that's relevant, but while I've never seen this behavior myself
I also do not use TAB files for vector data.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Hunter, David - St. Louis Park, MN
Sent: Tuesday, August 02, 2005 6:49 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] problem with tiled layer
I was able to reproduce the problem using version 4.6.  I can send you a
.map file, data and GET strings that would show the problem, if you're
interested.
Behalf Of Frank Warmerdam
Sent: Tuesday, August 02, 2005 4:11 PM
On 8/2/05, Hunter, David - St. Louis Park, MN <David.Hunter at fnf.com>
wrote:
> Should I try and upgrade to 4.6?  What would be involved, merely
copying
> the contents of the bin directory to my cgi-bin?
David,
Well, that depends on your circumstances.  Where you get your binaries,
etc.  Generally speaking the .map file and other application components
should be pretty compatible between 4.4 and 4.6 so the main issue is
replacing your binaries and support libraries with a newer version.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
