don't understand scale
Douglass Davis douglass_davis at EARTHLINK.NET
Wed Aug 3 21:33:58 EDT 2005
Ok, so the scale is relative to the units used in the mapfile.  I still
don't quite understand.  This example would help me a lot if any one
could explain it.
let's say I have a map with (fictitional units)
EXTENT 100 100 200 300
Now...  For example, what scale number will I have to use in zoomScale
to get a map scaled to exactly 100%.  Meaning, exactly the same map I
would get without scaling.  From that number I can get the other scales.
And can any one explain how they got this mathematically?
http://www.douglassdavis.com
Douglass Davis wrote:
> I am using php mapscript, and i want to zoom in to a point.  I have
> two options:
> zoomPoint and zoomScale...  I understand zoomPoint, because it just
> zooms by a percentage.  But, zoomScale, I am not understanding.  It
> zooms to a certain scale, which is a double.  What does that scale
> represent? What is the scale relative to?  The docs don't really
> explain this well.
> The reason I wanted to do this, is because instead of  zooming in and
> out relative to the previous map's extent, it would be better if I had
> about 9 zoom levels, kind of like mapquest.  level 1 would show the
> states, level 9 would be a close up of the street.   But each of the 9
> levels would be a fixed zoom amount, relative to the size of the
> original extent in the mapfile possibly.   Is this difficult to do?
