don't understand scale
Douglass Davis douglass_davis at EARTHLINK.NET
Thu Aug 4 00:30:41 EDT 2005
Ok, thanks for all the help everyone.  I guess mapObj->{scale}was the
magic number I was looking for.
Just wanted to point out though that oddly enough PHP/Mapscript you will
get -1 for scale, until you set the extent (or call another method on
the mapObj apparently).
here's the code:
$map = ms_newMapObj($map_file);
echo "<br>scale1= ".$map->scale;  // prints -1
// just setting to what it is already.
$map->setExtent(
    $map->extent->minx,
    $map->extent->miny,
    $map->extent->maxx,
    $map->extent->maxy);
echo "<br>scale2= ".$map->scale;  // prints real scale value
I thought this was strange... But, in case anyone is interested, this is
what I had to do to make it work.
http://www.douglassdavis.com
Stephen Woodbridge wrote:
> Douglass,
> Scale is the ratio of the real world extents of an image of your data
> compared to the physical rendered image of that data.
> SO say for example lets say you display 10 miles of real world data
> onto an image that is ten inches wide. Then you scale is 1 in : 1 mile
> or 1:63360 because 1 mi = 5280 * 12 inches
> For displaying on the screen we figure 72 dot per inch. If you are
> trying to figure out how to set minscale and maxscale values, most of
> us  add
>   <p>Scale 1:[scale]</p>
> to our templates or get the scale directly from the mapObj->{scale}
> and print it on out web pages. Then as we zoom in/out if always shows
> the scale.
> HTH,
>   -Steve W.
> Douglass Davis wrote:
>> Ok, so the scale is relative to the units used in the mapfile.  I
>> still don't quite understand.  This example would help me a lot if
>> any one could explain it.
>> let's say I have a map with (fictitional units)
>> EXTENT 100 100 200 300
>> Now...  For example, what scale number will I have to use in
>> zoomScale to get a map scaled to exactly 100%.  Meaning, exactly the
>> same map I would get without scaling.  From that number I can get the
>> other scales.
>> And can any one explain how they got this mathematically?
>>> I am using php mapscript, and i want to zoom in to a point.  I have
>>> two options:
>>> zoomPoint and zoomScale...  I understand zoomPoint, because it just
>>> zooms by a percentage.  But, zoomScale, I am not understanding.  It
>>> zooms to a certain scale, which is a double.  What does that scale
>>> represent? What is the scale relative to?  The docs don't really
>>> explain this well.
>>> The reason I wanted to do this, is because instead of  zooming in
>>> and out relative to the previous map's extent, it would be better if
>>> I had about 9 zoom levels, kind of like mapquest.  level 1 would
>>> show the states, level 9 would be a close up of the street.   But
>>> each of the 9 levels would be a fixed zoom amount, relative to the
>>> size of the original extent in the mapfile possibly.   Is this
>>> difficult to do?
