postGIS vs. TAB files
Paul Ramsey pramsey at REFRACTIONS.NET
Thu Aug 4 20:28:42 EDT 2005
David,
Frank might have to comment on the efficiency of his TAB support in
OGR to clarify, but in general PostGIS is more effective if you want
to consolidate management of data into one place, query/modify the
data from multiple applications/clients, and get better optimization
of composite spatial/attribute queries.  In straight speed metrics of
drawing a map, PostGIS vs shapefile favours the shapefile by 10-20%.
I am not sure if the same would be true of TAB, they have to traverse
an extra layer of abstraction (OGR).
Paul
On Aug 4, 2005, at 9:26 AM, Hunter, David - St. Louis Park, MN wrote:
> I know little to nothing about postGIS, but I was wondering if
> using it might have some advantages over Mapinfo .TAB files (and
> tile indexes) for use with Mapserver in a Win2000 environment.  Any
> feedback from people that have used postGIS would be greatly
> appreciated!
> David S. Hunter
> Sr. Software Engineer
> Fidelity National Geographic Solutions
> division of Fidelity National Financial
> 5353 Gamble Drive, Suite 201
> St. Louis Park, MN 55416
> š Email: david.hunter at fnf.com
> ' Phone: 952.542.1440 ext. 256
> 7 Fax: 952.542.3859
