SRS in OGC Viewer ok, but not in Mapbender!?
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Mon Aug 8 09:01:10 EDT 2005
Leopold,
1st problem is not a problem, Mapserver adds a group item which holds all your layers. This allows a WMS client to ask for all your layers at once, without specifying all the names.
2nd problem, can you try the following METADATA at the WEB and LAYER level:
"WMS_SRS" "EPSG:31287 EPSG:4326"
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Leopold Schefcik (MULTIMEDIAPLAN.AT)" <leopold.schefcik at MULTIMEDIAPLAN.AT> 08/08/05 01:58pm >>>
hi list,
1st problem:
I have a GetCapability Request for my map project with one single layer:
GetCapabilies Request:
http://213.47.127.15:8081/cgi-bin/mapserv.exe?MAP=/ms4w/apps/maplab-2.2\tuto
rial/gewaesser.map&SERVICE=wms&VERSION=1.1.1&REQUEST=GetCapabilities
In the wms viewer http://www.wmsviewer.com/main.asp
there are two layers (one is the right layer, and one has the name of the
map. What's that!?!?!?
____________________________________________________________________________
2nd problem:
in Mapbender I have the message: "msWMSLoadGetMapParams(): Invalid SRS given
: SRS must be valid for all requested layers.
(Mapbender-GUI:
http://213.47.127.15:8081/mapbender/frames/index.php?&gui_id=_PGO_)
I have 3 times an EPSG in my map-code:
A. at Map/Web/Metadata -> EPSG:4326
B. at Map/Prokection -> EPSG:31287
C. at Map/Layer/Metadata -> EPSG:4326
ist this right???
With this A/B/C configuration I have no Error message in the OGC WMS Viewer
but in Mapbender.
If I make all to 31287, I have an error message in the OGC WMS Viewer.
can anybody help me please?!?
Leopold
PS: The map and capability file is in the attachement.
