php_proj.dll - Not anymore included on PHP/MapScript package?
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Mon Aug 8 12:02:14 EDT 2005
Hi There,
Eduardo Patto Kanegae wrote:
> Hi,
> As far as I remember, the last package of MapServer/PHPMapScript from
> MapTools
> which included php_proj.dll was version 4.4.1
> Why is this *php_proj.dll* not included anymore at 4.6 package?
This package I think was mostly useful when projection information was
not exposode few years back through php mapscript. I think you can now
do all the projection conversions using php mapscript objects.
> Can I use this version using latest PHP 4.x or PHP 5.x?
the dll won't work with php5.x. It might work with the php 4.4
> Or is there a way to build it without needing *Micro$oft Expensive
> Studio* ? I mean,
> is it possible to do it using the free *MS Visual C++ Toolkit 2003* or
> another free compiler?
> How was this extension done? Was it 'SWIGed' from PHP+PROJ4 sources?
  There is a php_proj.c file manitened manulally uder the php/mapscript
directory. The makefiles have a taget called php_proj inside them.
  Although I have not tried it, It should be able to build using the
free MS Visual C++ Toolkit 2003.
> best regards
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
