Using attribute info stored in MySQL tables
Matthew Haines
matthew at PROPERTYRESEARCHPARTNERS.COM
Tue Aug 9 10:42:00 EDT 2005
In my Mapserver application I am generating my maps from shapefiles.
Since my application is used for real estate, usually the shape files
hold land parcel polygons, and usually the parcels will be uniquely
identified by a parcel_id attribute. There are usually some other
attributes such as zoning class that I can use to color the map.
But sometimes I'd like to color the map based on attributes that are
stored in a MySQL table that has the parcel_id has the primary key.
However I don't have the polygons in the MySQL table -- they remain in
the shape file.
Is this possible? What would I put in my .map file to reference the
MySQL tables? Can someone sketch out an example of the crucial bits of
a hypothetical .map file for this? I looked in this Twiki page
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MySQL
for examples, but it seems to cover only the case where the polygons are
stored in the MySQL table.
Thanks in advance,
Matthew
