Shapefile Problems
Zamil Murji Zamil.Murji at DIVESTCO.COM
Wed Aug 10 17:15:33 EDT 2005
I believe I answered my own question. Projection issues...the new absale1 file was missing a shift in the X coordinate.
Thanks and sorry for the troubles.
Zamil
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Zamil Murji
Sent: Wednesday, August 10, 2005 2:50 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Shapefile Problems
Hello list,
My maps have recently run into a problem with a specific shapefile. The problem just started happening (they had all been working in the past).
Here are the details:
1) Both of the attached shapefiles work in arc explorer.
2) The seis3dfill shapefile works with the specific layer in question, but the absale1 is the one that is acting up.
Here is the url in question. It returns an empty image when I use the absale1 shapefile and an image filled with polygons if I switch it to use the seis3dfill shapefile. No error msgs are produced.
http://idcmap.divestco.com/cgi-bin/mapserv?mode=map&map=/mapfiles/sdb-client-side.map&mapext=9257858.00000+2992248.10443+11712816.00000+5189146.89557&mapsize=723+647&layers=&map_seismic2d_class_expression=/(.)/&layers=&map_seismic2dlibrarycard_class_expression=/(.)/&layers=&map_seismic3d_class_expression=/(.)/&layers=&map_seismic3dlibrarycard_class_expression=/(.)/&layers=&map_seismic3d-outline_class_expression=/(.)/&layers=absale1
Here is the layer definition.
# ALBERTA SALE 1
LAYER
  NAME absale1
  TYPE POLYGON
  STATUS off
  DATA /mapdata/canada_data/landsales/absale1
#  DATA ./seismic/seis3dfill
  CLASSITEM 'agreement'
#  CLASSITEM 'TEXT1'
#  MAXSCALE 250000
  LABELITEM "sale date"
#  LABELITEM 'LINENAME1'
  LABELMAXSCALE 200000
  SYMBOLSCALE 120000
  CLASS
    EXPRESSION /./
    OUTLINECOLOR 0 0 0
    COLOR 255 149 46
    SYMBOL 0
  LABEL
      COLOR 0 0 99
      TYPE TRUETYPE
      FONT arial
      FORCE on
      ANGLE 0.000000
      POSITION cc
      SIZE 5
      MAXSIZE 20
      MINSIZE 1
    END
  END
END
Any help would be appreciated.
Thanks
Zamil
