nearest feature
Miguel Gonçalves
mgoncalves at DSI.UMINHO.PT
Thu Aug 11 05:22:02 EDT 2005
I am using MapServer in order to build a local-based context application.
I use a mapfile with several layers ansd I use a WFS request to get the
geographical information related to a given point.
Normally I use a request of this type:
http://mapserv.exe?MAP=mymap.map&
SERVICE=wfs&
VERSION=1.0.0&
REQUEST=getFeature&
TYPENAME={all the layers}&
BBOX=-8.418000,41.539600,-8.418000,41.539600
My problem is when the point that I pass in the BBOX does not coincides
geographically with any geographic feature in my map.
In those cases, is it possible, for each layer, to get the nearest feature?
You see what I mean? If I pass the point (x,y) in the BBOX and the
nearest feature to (x,y), in a given layer, is located in (a,b),
is there any type of interface that gives (a,b) as result?
