help! Mapserver installation!
corvao
viperp at GMAIL.COM
Thu Aug 11 10:26:13 EDT 2005
Hi everyone! I've got a pretty big problem here, I can't install the
mapserver correctly.
System configuration:
- Debina Stable
- Apache2
- php 4
- mysql
- mapserver 4.6
- Everything, except the mapserver, was installed using the apt-get install.
- Procedure used for mapserver installation:
- cd mapserver 4.6
- ./configure --with-gd --without-tiff --with-freetype --with-proj
--with-ogr --with-gdal --with-wmsclient
--with-php=/home/ler/php 4
- Where /home/ler/php4 is where I unzipped the php4, made the
./configure and the make
- Next I copied the file called mapserv generated by the mapserver to
the apache's cgi-bin directory
- And copied the php_mapscript.so file to /usr/lib/php4/20020429/
And the error is the following:
Warning: [MapServer Error]: getString(): Parsing error near
(none):(line 36) in /var/www/sipeas_novo/htdocs/index.php on line 35
Warning: Failed to open map file 2.map in
The erroneus part of index.php is the following:
if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
$dlext = "dll";
else
$dlext = "so";
dl("php_mapscript.so");
include("index.inc.php");
if ($HTTP_FORM_VARS["CODIGO_MAPA"]){
$gpoMap = ms_newMapObj(strval($HTTP_FORM_VARS["CODIGO_MAPA"]).".map");
else{
$gpoMap = ms_newMapObj("1.map");
Can anybody help? I can be contacted by either msn or email.
ty
