Swf layers
Jorge Agudelo jorge.agudelo at PREMPER.COM
Fri Aug 12 08:23:08 EDT 2005
Hello Everyone,
It is possible to change the way mapserver generates the code for swf =
layers with swfdumpattributes?, the problem is that mapserver generates =
a lot of code for every object (onrollover, onrelease), this code could =
be done dinamically using a for cycle when loading the swf  this way  it =
will decrease a lot the swf size.
The problem is that if the swfdumpattributes tag is deleted the objects =
of the layers becomes shapes so it is no possible to work with them by =
code. It is there anyway to tell mapserver that make the objects be =
buttons but not to put code for every object?
Thanks for your time.
Jorge Agudelo
