MrSID Error
Frank Warmerdam fwarmerdam at GMAIL.COM
Mon Aug 15 10:54:22 EDT 2005
On 8/15/05, Shaik A. Hussain <shussain at atsincorp.com> wrote:
> Hello List,
> I am getting the following error with the MrSID layer file. Can any one
> help me how to fix this error.
> msDrawMap(): Image handling error. Failed to draw layer named 'MrSid'.
> msDrawRaster(): Image handling error. Unrecognized or unsupported image
> format
Shaik,
Whether or not your MapServer instance supports MrSID format for
input depends on whether your GDAL is built with MrSID support.
Try:
  gdalinfo --formats
to list all GDAL support formats in your build.  Likely you do not have
MrSID support enabled.  It can be a bit involved to build in.
Best regards,
