group by clause
Jason FU
tsfu at HKUCS.ORG
Tue Aug 16 00:24:00 EDT 2005
I've got it. Thanks!
Jason
On Mon, 15 Aug 2005 20:44:06 -0700, Ken Lord <kenlord at GMAIL.COM> wrote:
>Hi Jason,
> You could try a DATA string something like this ...
> DATA "the_geom FROM (SELECT * FROM sounding.sdgonly_20050722point WHERE
>elevation > 0 AND mod(gid, 300) = 1 GROUP BY the_geom HAVING max(dispx) >
>86738) AS foo USING UNIQUE gid USING SRID=26910"
> .... I've capitalized the SQL keywords just to make them more readable. The
>DATA string should all be on one line (not sure how this will post to the
>list).
>.... Use the appropriate SRID number in place of 26910, representing the
>projection of your data.
> Cheers,
>Ken Lord
>Vancouver BC
>On 8/15/05, Jason FU <tsfu at hkucs.org> wrote:
>> What do I do for the sql statement as follows:
>> select the_geom from sounding.sdgonly_20050722point
>> where elevation > 0 and mod(gid, 300) = 1
>> group by the_geom
>> having max(dispx) > 86738
>> CREATE TABLE sounding.sdgonly_20050722point
>> gid serial NOT NULL,
>> recno int8,
>> elevation float8,
>> dataflags int8,
>> dispx float8,
>> dispy float8,
>> size float8,
>> angle float8,
>> scale int8,
>> keyword varchar,
>> usernum int8,
>> fcode varchar,
>> datatype int4,
>> descflags int8,
>> themenum int8,
>> indexkey varchar,
>> superflags int8,
>> sourceid varchar,
>> the_geom geometry,
>> CONSTRAINT sdgonly_20050722point_pkey PRIMARY KEY (gid),
>> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
>> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
>> 'POINT'::text OR the_geom IS NULL),
>> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = -1)
>> WITH OIDS;
>> I tried this one in MapServer but it doesn't work at all.
>> DATA "the_geom from sounding.sdgonly_20050722point"
>> FILTER " (elevation > 0 and mod(gid, 300) = 1) # group by the_geom "
>> Please advise.
>> Thanks.
>> Jason
