Where can I find EPSG codes?
Tyler Mitchell tylermitchell at SHAW.CA
Wed Aug 17 16:17:35 EDT 2005
Hi John,
I'm assuming you have a working MapServer install running, is that right?  There is a file named 'epsg' that is part of the proj4 projection system, it defines what all the numbers mean.  Search your system and see.  If you don't have that already, you can grab some files from: http://proj.maptools.org/ and see it.
Hope that helps.
Tyler
----- Original Message -----
Date: Wednesday, August 17, 2005 1:12 pm
Subject: [UMN_MAPSERVER-USERS] Where can I find EPSG codes?
> I'm looking for NAD_1983_StatePlane_Alabama_West_FIPS_0102_Feet.
> I've done
> a google search on EPSG and lookup (among others) and haven't
> found it
> (though it might be in there somewhere :-)
> Where do you look up this stuff?
> Thanks,
> John Cole
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom
> they are addressed. If you have received this email in error
> please notify the system manager. This message contains
> confidential information and is intended only for the individual
> named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail.
