Where can I find EPSG codes?
Aaron Racicot aaronr at ECOTRUST.ORG
Wed Aug 17 16:34:36 EDT 2005
John,
Just realized that the EPSG entry that I sent you was in meters, yet the
name of the projection you are trying to locate has "Feet" in the
name... Looks like you might be after a non-standard projection that is
not defined in the EPSG file?  I am not familiar with Alabama's state
plane coordinate system but it looks like they are in meters, so you
might have to do some local digging or define your own projection and
forgo the convenience of the EPSG codes.
Good luck...
Aaron
| Aaron Racicot  | aaronr at ecotrust.org   |
| GIS Programmer | 503.467.0759          |
| e c o t r u s t                        |
| Jean Vollum Natural Capital Center     |
| 721 NW Ninth Avenue                    |
| Suite 200                              |
| Portland, OR 97209                     |
| www.ecotrust.org                       |
-----Original Message-----
Sent: Wednesday, August 17, 2005 1:28 PM
To: 'John Cole'; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] Where can I find EPSG codes?
John,
The EPSG codes can be found using your local installation of PROJ.4.  On
my machine this is located at:
/usr/local/share/proj/epsg
I also took a quick look and found this in the EPSG file... Hope it
helps.
# NAD83 / Alabama West
<26930> +proj=tmerc +lat_0=30 +lon_0=-87.5 +k=0.999933 +x_0=600000
+y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs  <>
Aaron
| e c o t r u s t                        |
| Suite 200                              |
| www.ecotrust.org                       |
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of John Cole
Sent: Wednesday, August 17, 2005 1:13 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Where can I find EPSG codes?
I'm looking for NAD_1983_StatePlane_Alabama_West_FIPS_0102_Feet.  I've
done a google search on EPSG and lookup (among others) and haven't found
it (though it might be in there somewhere :-)
Where do you look up this stuff?
Thanks,
John Cole
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. If you have received this email in error please notify the
system manager. This message contains confidential information and is
intended only for the individual named. If you are not the named
addressee you should not disseminate, distribute or copy this e-mail.
